Eh? Since when is a dynamic or static IP nearly twice the price?justify paying for example almost double the price.
Toob are their own alt-net with ~100k subscribers, so no one can compare directly to them apart from other small alt-nets. You can't really compare them to ISPs which offer services to over 90% of the UK. And as you mention, they offer a static IP which is not, and as you quote, double the price.provider price for example Toob can be had for £22 900/900. (They do offer Ipv4 static for £8 extra)
Again, they are comparatively speaking a small ISP with a limited UK wide footprint.which provider that offers static is that price?
Ones which cover most of the UK?most of the ones i have looked at are £40+
Someone does something naughty on the IP they share with you, you then get banned on that service when they ban the IP. Your household already shares an IP with no CGNAT, because NAT is standardised.It really is nothing like sharing your credit file more like sharing your home address so it really is not a big deal at all.
Why would it matter what others do it doesn't.
I tried to find a list of providers which are CGNAT couldn't find a complete one but it looks like 90% of UK is this and if you want static you pay extra.
Worth enabling and you'll keep your ipv4 address, if you look at your account you'll see your ipv4 & 6 addresses.
City Fibre checker now says I can connect to the City Fibre network and gives me a list of ISPs I can use. Is that list the only ones I can use as I can't see some of the ones recommended on here such as Sky and Aquiss.
Tried that and says I can't have it so the list must be the only ones I can use. Have edited some of them into my last post.You'll be better off putting your details directly into Aquiss etc to check for services or reach out to them, Martin + rest of support are on the ball usually.
The list of support ISP in my area also shows no Aquiss, but I'm having it switched over this coming Friday from Cooko (on cityfibre) to Aquiss 2.5gb connection. it's not a bad deal really atm it works out to £49 a month and I was paying £41 to Cookoo inc static ip for 900meg. Aquiss seem to have a pretty good reputation I will report back friday with how it went and what they are like for you.Tried that and says I can't have it so the list must be the only ones I can use. Have edited some of them into my last post.
100% even their website told me I could get it even though not listed on CityfibreYou'll be better off putting your details directly into Aquiss etc to check for services or reach out to them, Martin + rest of support are on the ball usually.
