MSI's X570 Tomahawk May Become Go-To OC Board??
I appreciate the responses. Maybe my problems have coincided with the Win11 update. Currently having a nightmare with the graphics drivers crashing and resetting when I move programs between monitors. I have a dedicated thread for that subject though.
I've narrowed down the problem to my mobo or cpu.well, I think I have...
I am now on Windows 11 25H2 and the only problem i had was Adrenalin was not detecting my 9070XT, but reinstalling the driver sorted that out and has been fine since.
Noticed you got yourself a new build, are you having these problems on both or just the X570?
New build is still in it's various boxes behind me while I finish off some work so only noticed the issue on the machine in my sig.
Have you tried older/newer drivers?
Yeah the problem was happening on drivers I had running for about a year. I updated the drivers from the MSI web page and the problems persisted.
It may end up being a software issue - ie PowerToys or something running in the background. If it is hardware though, it's pretty much CPU or Mobo.
I would try chipset drivers direct from AMD
I was actually meaning the Nvidia drivers though, have read some versions are not good and a lot of people are going back to old drivers.
What version of W11 are you on, 24H2 or 25H2?
Don't even know if this would be related to your problems with a dual monitor setup as i have only ever used one monitor.
