I didn't realise people had complained that the FE versions were affected.
Mine doesn't have any coil whine either, luckily.
Yes there have been people who have returned FEs due to excessive coil whine.
5090 Suprim Liquid stock running CPPT 3D Adaptive coil whine test - Spinning cat
Was basically silent on Furmark 4K 240
So I'm happy with it,
now I'll undervolt it.
Did they accept the RMA?I just found this thread and wanted to post my RTX 5080 FE coil whine. It's kinda unbearable, I can even hear it when I'm scrolling through a web browser. I'm in contact with Nvidia hoping I can RMA it, I will try undervolting.
It does seem FEs have a higher tendency for more severe coil whine, at least based on the early reviews and what I have read. Thankfully mine is very minor. Swapping PSU helped as well (needed to do it anyway as was on an 850w PSU beforehand).Mine aren't too bad TBH. FEs, just luck of the draw tho; I've had an horrifically loud 3090FE I had to return.
The RTX 6000 PRO is pretty good for that. Although at that price… the ******** had better bloody well make sure it’s perfect lol.It does seem FEs have a higher tendency for more severe coil whine, at least based on the early reviews and what I have read. Thankfully mine is very minor. Swapping PSU helped as well (needed to do it anyway as was on an 850w PSU beforehand).
Hey, guys! This is my Vanguard 5090 - undervolted to 0.900 - 2700mhz and +3000mem.
In this video, the Speedway benchmark is running. It’s not any high-pitch noise, but rather a low-frequency buzzing. When I close the case and the room is completely silent, I can hear it. Is this low coil and acceptable ?
Yes, I’ve already had so many RTX 5090 cards and every single one of them buzzes. I use undervolting, and when I’m playing and sound is coming from the speakers, I can’t hear anything at all. But as soon as I go into a menu or there’s a quiet scene in the game, I can hear a buzzing sound from the closed case. It’s not extreme, though. Is that still normal?Sounds fine to me. But the only opinion that matters is yours. The fact you're asking a forum shows you're not 100% happy.
For me personally unless I can hear it above gameplay, or 6ft away where I sit then coil whine isn't a problem.
A card that makes no noise at all just doesn't exist and I think it's too easy to just get caught up looking for the holy grail.
Yes it's normal not had 1 5090 that was actually coil whine free (at higher refresh rates at 4K 240Hz for example)Yes, I’ve already had so many RTX 5090 cards and every single one of them buzzes. I use undervolting, and when I’m playing and sound is coming from the speakers, I can’t hear anything at all. But as soon as I go into a menu or there’s a quiet scene in the game, I can hear a buzzing sound from the closed case. It’s not extreme, though. Is that still normal?
I thought that if I hear a buzzing from the case in silence, I have a bad card. Of course, I don’t hear anything with headphones or speakers, but as I mentioned, in quiet scenes when I don’t have a headset, I can hear it.Yes it's normal not had 1 5090 that was actually coil whine free (at higher refresh rates at 4K 240Hz for example)
Lower fps targets 144Hz/120hz and it is.
But nothing extreme
I am at 4K, I have a LG C4. My fps are uncapped. Do you think that many of ppl hear buzzing in silent room?same as me, it's not ideal, but it's normal imo depending what resolution/fps you're playing at.
I’m running above the monitor’s limit, which means I sometimes get 150, 180, or 230 FPS.So 4K 144Hz?
still hearing it is normal imo but it should be softer than running it at say 4K 240Hz, maybe try capping it at 150Hz or something just to see if it reduces it or not instead of uncapped.
Yep, try limiting it to 144hz (or 141 if g-sync is enabled). It should help. Although if you upgrade to a 4k 240hz monitor in the future it will return. It’s just life with most 5090s.I’m running above the monitor’s limit, which means I sometimes get 150, 180, or 230 FPS.
