you actually need FG with a 5090?
No, it defaulted to it when I pressed optimise in the app lol. Don't think I'll get 120fps though at 4k with PT.
PT is worth some sacrifices in C2077No, it defaulted to it when I pressed optimise in the app lol. Don't think I'll get 120fps though at 4k with PT.
I'm getting 70-85 maxed out using DLSS Balanced.
Although my computer room is now 500° but it's still better than seeing all the horrible artefacts and weird shimmering from frame gen.
I wish DLAA didn’t feel so laggy because it looks fantastic. It actually holds up well in terms of frames, but it just doesn’t feel great. Not that DLSS quality is visually far behind.
Yeah there's no perfect solution ATM, all have a tradeoff somewhere. Sure it will improve.
yep you'll get old and your eyes wont notice the artefacts and shimmer anymoreYeah there's no perfect solution ATM, all have a tradeoff somewhere. Sure it will improve.
Is it worth buying this and is it better on PC or Xbox?
This, so much this!Yes, and get it for the PC.
Very much (several months later after continuous playing) yes and PCIs it worth buying this and is it better on PC or Xbox?
Ha, was thinking of a replay after being away from the game for quite a while.Ah **** here we go again then for the 5th playthrough! What a time to be alive!![]()
Fifth?Ah **** here we go again then for the 5th playthrough! What a time to be alive!![]()
