1. There shouldn't be any noticeable difference in sound quality between the single-ended and balanced interconnects.
2. It depends on the tube amp, some amps it might be a passive passthrough in which case it can work when off, and others will work as a pre-amp and will need to be powered on.
Technically no but there is with the WARMER, the soundstage/imagine is slightly less wide with RCA output vs XLR output. I tested this in depth when testing if both outputs work at the same times without sacrificing SQ and A/B switching on the A90D showed that soundstage was better via XLR output, even though the output power of the RCA was slightly higher than the XLR.The difference was noticeable on both HE1000se and speakers.
K15 and 17 have the same 4.4 balanced input yeah, so if you have the correct cable, no reason not to use it and be fully balanced.
Thanks for the replies.
I think the only issue with balanced input on the K15/17 is going to be that it is 4.4mm based. It seems to be cheaper with more choice when buying XLR to XLR vs. 4.4mm to XLR cables. But part of me feels like the Warmer wasn't really designed with these DAC/AMPs in mind (hence that other new AMP incoming).
Regarding the OTL tube amp scenario it'll just mean I can run off one RCA output if I can turn it off. I'm only ever going to use an OTL for headphone use.
