- 6 Jan 2003
Hi
I have an Asus X570 TUF Gaming WiFi with 5800X3D and RTX5080. Both NVME slots are used and I wanted to add a 3rd. As it'll be used for image processing, can I use the 2nd PCIe big slot to add an adaptor? Would this affect the 5080 performance? Or should I just stick to a SATA drive for the extra storage? Did some googling and the the 2nd x16 slot is actually only x4 and runs off the chipset, not the CPU like the main slot? If that's the case and my GPU won't be affected, are there any recommendations for adaptors?
Thanks
Andy
Thanks
Andy
