FRITZ!Box 7530
31 Oct 2006
Uttoxeter
Hey,
Can anyone tell me in SUPER simple terms how to make this modem/router just a modem? I looked at some guides but im really not that tech savvy and dont reall understand them.
I want to make it just for internet and then get a Amplifi instand or HD, connect that Via a Ethernet cable so it can handle all of my wifi in the house to try improve signal.
Regards
Carl
So you want to use a Ubiquiti Amplifi to provide Routing and WiFi have I got that right?
I’ll explain how to to put the 7530 into modem mode when I get home but its super simple.
Yeah basically Fritzbox just as the modem so I can plug for example a Amplifi HD router into it and then put the mesh points upstairs so that the Amplifi handles all the wifi in my house
First of all i went into the Wireless > Radio Network > Active Frequency Bands > Turned off both 2.4 and 5Ghz can't remember if this step is needed but it does not hurt.
To put 7530 into what it calls a modem mode go into Internet > Account Information > Internet Service provider > Other Internet Service Provider > Name (i called mine Modem Mode) and copy the settings i have in the pictures.
I am using Zen so the Connection settings work for me, i'm not 100% they will work for you if you're with another provider.
https://i.imgur.com/pBvMYYy.png
https://i.imgur.com/ZfWmFRj.png
pBvMYYy
ZfWmFRj
I am also with Zen.
So this way I can connect lets say this:
My basket at Overclockers UK:
Total: £420.65 (includes shipping: £8.70)
one of the boxes via Ethernet to my FRITZ!box so thats my new Wifi then I can have the other box upstairs linked to the first box in a mesh system for better internet.
Sorry if I keep asking the same questions, just dont wanna blow lots of money on stuff and it not work how I want/think it should work.
I am also with Zen.
To use those devices you would just need to turn the WiFi off on the Fritz box if you put it into Modem mode your network wouldn't work as you would have no Router as the devices you linked are purely WiFi Access Points they have no Routing function, in your initial post you said you Amplifi which has a built in Router.
The items you linked do seem over priced as well.
Ah I thought one of them was a router and the other was a wifi point. Yeah I said Amplifi but wasnt sure if i should futureproof myself and go Wifi 6 (as when I build my new PC it will have wifi 6 on the board already) and I dont think Ubiquiti do any Wifi 6 mesh systems.
pBvMYYy
ZfWmFRj
May I just thank you after spending hours searching for an answer and all sorts of other settings your step by step advice was a god send!!
Dont know how the stay home is treating you but you could be a yoda if you choose!!!
Out of interest How's the fritzbox? Is it say as decent as the bt home hub 6 or bt smart hub?
The Fritzbox is ace. It's feature packed. It gets frequent updates.
It does DECT, VoIP, FTP Server, VPN, USB Server, mesh network with multiple units, guest network. It's very good.
I'm trying to find one of the Fritz Repeater boxes. Zen have offered me a box for about 12 quid per month which is ridiculous
Anyone found an UK seller with the Repeater 2400 or 3000 online?
pBvMYYy
ZfWmFRj
Just to bump this - I have just used these settings now in 2025 6 years later with my Fritz 7530 AX running the latest version 8 software and it worked a charm - thank you
Silly question - I am unable to open images, can someone help please? I'm trying to run F7530 with Talktalk in bridge mode. Many thanks for help.
From what i remember; do what i typed in posts. Plus in the video at 2:05 make sure the following options are selected: "Maintain Permanently" "Via the Fritz!Box" and "Connected devices are also allowed to ....." are
Thank you, your help is greatly appreciated :).
Judging by the long lifespan of this thread there's a lot of people having similar issues with Zen... Our broadband/phone service (via Zen) has been moved over to digital voice. I've been using an Asus RT AX59U (via a Draytek vigor 130) as a home router up to this point. I've tailored it to our home needs, including VPN settings, and I don’t want to have to replace it.
I followed the very clear steps above, set a modem mode profile, and linked up my freebie 7530 from Zen to replace the draytek. All good, except no phone service... Which makes perfect sense if the 7530 needs to log in to Zen for phone services. So I'm assuming this approach wouldn't work for voice services and I'll either need to try something different or give in and use the 7530 on its own (or upgrade to a 7530 AX for wifi 6). Any suggestions?
You would need your digital voice credentials from Zen. From what I remember when I worked there 4 years ago they are very reluctant to give this out as they don't want to be in the situation where customers are expecting them to support 3rd party hardware so all I can say is good luck, hopefully you'll get one of the good guys who will give you the credentials after explaining to you they will not offer any support on 3rd party hardware.
If you google there are some other solution involving connecting your Fritzbox to your own router and just using it for telephony but I don't know how successful you would be trying this.
Well I finally got some time to call Zen and got through to one of the good guys straight away! Now I just need to hook up the Fritzbox to replace the Draytek. Thanks so much for the suggestion!
