Rodent problem
22 Feb 2014
I have some sort of rodent in my attic, a few weeks ago one of my CCTV cameras went B&W, I thought it was just an old camera and was dying.
Then a couple of days ago I notice it had gone off line,
When I removed it from the ceiling the wire had been chewed.
can anyone tell from these images if this is rats or mice ?
I haven't been up in the attic to inspect yet but its not an easy attic to get into
Could be either. Time to put some bait traps up there.
Check your service ducts for points of ingress, soil stack etc...
i know where they have got in (I think). I had a look around the property and both ends of the soffit on one side of the building are completely open, I didn't realise they had been left this way when they were replaced a couple of years ago.
Should I clear the infestation first or block the soffits first ?
I'd attempt to get rid of the infestation first as it might have been them that created it entrance and will do so again. Get rid of as many as you can then block it up when the numbers drop.
I'd suggest one of those buckets with the seesaw on the lid and bait it with your treat of choice (chocolate, peanut butter etc). The vermin climb up a ramp to the top of the bucket and they fall in. Make it a murder-bucket by filling it with water or dispense with the live mice/rats as you see fit. Poison can be a bit risky if you have pets and other wildlife around that may snack on the mice they find, plus you don't know where they go to die and rot.
I'm not a roofer or a rat catcher, but I'd probably do both at the same time. Contain the threat and eradicate, with prejudice.
In all seriousness I'd get a roofer to examine the ventilation setup in your loft, those soffits may be like that for a reason. That said you could put some mesh of a vent or something there to stop ingress and keep an airflow.
I recall reading that mice are more likely to chew things than rats, where rats are more likely to carry diseases.
Good luck! :eek:
well i need to replace the camera in question, so might as well set it up in the attic first to determine what I'm dealing with.
also could be an elephant up there with the size of the gaps that have been left by the joiners.
Had a rat find a way into our kitchen a couple years ago. They are devious persistent little buggers. Found it was getting in through an old pipe hole in the extension. Tried just sticking a rock lying around in it.
Nope, it pulled the rock out.
Sealed the whole hole with silicon sealant. Completely airtight. Nope, it ate through it and came in again. Got pest control at this point, guy assured me they can’t deal with wire wool. Hah. That got chomped and removed.
Ended up piling bricks and wedging our boot store up against it. Stopped the little sod.
Anyway waging war on rats is quite entertaining :)
I would bet money on mice, they love to chew stuff up and are quite quiet.
To ID them you need to find their droppings. They poo A LOT so usually easy to find.
Then you can get the right bait / traps.
Day 2 of having the camera "installed" in the attic and we got some motion early hours of this morning
What is the best way of dealing with these ?
poison or trap ?
I don't know what to buy tbh.
