**THE NVIDIA DRIVERS THREAD**
ffs I jinxed it!
I've never had a driver hang on this card before!
So much for the new drivers :cry::cry:
You clearly need a new GPU. :)
They released a new CUDA toolkit and I realised my one was rather out of date so I updated them both, hopefully goes well! :D
Does this give any benefits ?
But actually should I try then.....
You should but remember to pray at your Altar of Huang !
Light the lime green candles, Put on your lime green mankini and then pray to Jensens jacket while reciting -
Oh mighty silicon spirits of NVIDIA,
we humbly bow before the glowing altar of our GPUs.
Bless us, O Jensen Huang, guardian of leather jackets and CUDA cores.
Guide the sacred drivers so they may install without errors,
compile without warnings,
and run without mysterious crashes at 2:17 a.m.
Deliver us from the curse of “clean installs,”
from the abyss of random black screens,
and from the eternal question: “Did you try rolling back the driver?”
Grant our frames to be high,
our temps to be low,
and our game updates to never require a hotfix.
In the name of the RTX, the DLSS,
and the Holy CUDA Toolkit—
Alt+Tab. Amen. ️
Tested with RE9.
Code:
577.00 Studio : PT : DLSS-P : 2xFG : 4K
Average framerate  :  122.1 FPS
Minimum framerate  :  117.4 FPS
Maximum framerate  :  125.7 FPS
1% low framerate   :   52.7 FPS
0.1% low framerate :   48.2 FPS
595.79 Studio : PT : DLSS-P : 2xFG : 4K
Average framerate  :  120.6 FPS
Minimum framerate  :  115.2 FPS
Maximum framerate  :  126.9 FPS
1% low framerate   :   52.6 FPS
So within run-variance, looks like they sorted PT performance. Maybe they will stay, for now :p
Tested with RE9.
Oh I'm sure someone will discover some bug somewhere that can cause your GPU to explode and kill next doors cat.
