I'm experiencing the opposite; I find the ANC very good. It's on par with the Sony WF-XM5.Not a fan of the buds 4 Pro, noise cancellation is weak even when maxed. It's a good fit, not loose at all. Weird.
Walking about I could hear almost everything, ANC is working but its not doing much.![]()
Looks like Samsung Slim magnet case is due to be delivered today, initially was 17/05, then 31/05 estimate.
Anyone got one? Reviews on Amazon aren't flattering so tempted to just chuck it on eBay.
sammyguru.com
Strange, might a fit issue but they don't seem loose, quite the opposite. I haven't seen many users praising the ANC.I'm experiencing the opposite; I find the ANC very good. It's on par with the Sony WF-XM5.
I use a Torras screen protector, which is extremely easy to apply and does a great job. They are a little more expensive than some, but I've tried others and these are superior. I went for the standard version, so they are very reflective, which is the only negative thing I would say. I believe they do a anti-reflection version, but you obviously pay more.Just picked up a S26U what are people using screen protector wise (ESR etc) and is anyone using the protectors for the rear camera lenses?
Thanks. You’re spot on re AR protector from them I think the cheapest I’ve seen is £35 for a 2pck. They do a Lena guard option as well I see. The Q3 air looks solid as well though pricey.I use a Torras screen protector, which is extremely easy to apply and does a great job. They are a little more expensive than some, but I've tried others and these are superior. I went for the standard version, so they are very reflective, which is the only negative thing I would say. I believe they do a anti-reflection version, but you obviously pay more.
I don't use anything on the rear camera lenses and never have done in all my years using Samsung phones.
That looks similar to the spigen optik which I’ve considered but I quite like the spigen nano pop.I'm using this case. It has a slidey door thing to cover the rear camera lenses for when placing the phone on a table or in a pocket. Different colours available.
The Pixel 10 Pro is the preferable option, given that custom ROM support should be available by the time Samsung ceases software updates.Hello , need some advice s26 base for £589 or pixel 10 pro for £649 , which one would you pick , battery life , stability, build quality and longevity are more important than cameras or a.i gimmicks ? Pixel software and one ui I don’t have a favourite I have used both before, thanks
sammyguru.com
Using a Spigen Ultra Hybrid case and Glass.Tr Screen protector. Fits perfectly with one another.Just picked up a S26U what are people using screen protector wise (ESR etc) and is anyone using the protectors for the rear camera lenses?
