Excuse if I'm crossing wires or something but that is interesting and after a lot more recent listening to music between DAC filters I have some thoughts on this and whilst that thread is geared on measuring the filter output and how faithful it is to the ground truth by tools, I can't hear the difference between NOS and all but one of the other DAC filters on the X8, the De-emphasis filter is brand new and exclusive to the X8 and is claimed to replicate the AKM Velvet house sound of the X9. For the most part this seems to be true, it is audibly less detailed at the top end vs the other filters which coincides with the X9 having a more laid back signature without the extended sparkle/detail at the top that the X8 does have along with a slightly more forward midrange.
The key point I think is that the above thread is focused on /DAC/ only with its respective filters (specifically ESS), and not accounting for the accompanying sections of the whole unit around the DAC that further filters and/or tunes the sound before reaching the ears since models like these have different characteristics in this sort of context.
So whilst it's right in that there's a lot of misunderstanding out there from users to reviewers and a lot of marketing bs by brands and dealers, the reviews aren't reviewing purely the DAC stage alone, because changing a filter can gel differently with the surrounding components within the DAC's local chain/ For example, the X8 uses dual mono parallel channels in its amplification stage with the quad CS DACs per channel and that as a whole produces a sound that is not what you get from any other CS based DAC including the Topping Octo (same chips, slightly less detailed and more laid back).
I think what's needed is all available models compared both objectively and subjectively from one outfit, at present there is different info and takes from hundreds of different sources and all saying their own things, GPT is great at averaging what's out there and giving a good impression of what's what, but still, things could always be better?
