Bad time
29 Dec 2012
"Wrong section"
I’m not sure if it’s worth upgrading at the moment. I’ve been told that prices for everything have become quite ridiculous. Originally, I was aiming to move to the AM5 platform last year, but I’m not sure the performance jump is there, even if prices were normal.
My current specs are:
  • CPU: Ryzen 7 5800X + Noctua U12S Heatsink
  • Motherboard: ASUS Crosshair VI Hero (X370)
  • RAM: 32GB (my last upgrade)
  • Storage: samsung 1TB SSD NVME M.2 + 3TB & 4TB HDDs
The 'weak links' are:
  • GPU: Back to using my GeForce GTX Titan X
  • Monitor: 24" 1080p screen"
Have they also gone up in price? or am I ok with monitors ?
Do your homework when taking advice from hornet.
Upgrade your GPU, that'll be massive bottleneck. Deals pop up in the MM frequently. You don't need the latest and greatest, I just bought a 5060ti and it works fine at 1440p, if not stellar.
what are the prices like at the moment and what would you recommend ?
anything things would be a little better but I want a half decent upgdade for the price without spending too much. under £150 if possible.
Honestly I'm probably the last person who should be answering that question, you'll get much better advice in the GPU forum.
That being said, I just sold a 2070 Super with faulty fans for £50, the new owner tinkered a bit and got it working so there are definitely deals to be had if you look around. That card is 50% faster than your Titan X.
Just gotta be clever and strike as soon as you can.
Keep an eye on the MM if you have access.
Thanks, I think ill aim for a GPU and Monitor for now, Im think something a 2070 or better would be the best option for a decent upgrade. and monitor 27"-32" maybe a 1440p nice display.
any thoughts ?
@2023 what's your budget and which games are you playing? If you get a 2070 you might find yourself wanting to upgrade again in the near future.
On my old rig I have a 5800X with an RTX 3080. Full PC spec is probably still in my sig. It runs my CAD software and highly demanding games really well.
any thoughts ?
2070 is pretty old.
Find out what a upgrade over a Titan X is...also you'd want a GPU with 16GB VRAM.
I take it it's the original Geforce GTX Titan X (Maxwell based), rather than the newer Pascal based NVIDIA Titan X)?
In which case there are a whole range of options if looking at used, but main thing would be to try and stick with something at least 12GB of VRAM
aiming for around £150 maybe a little more, the Titan X can still handel most game maybe not as good as what a new car would offer. 2070 super/ 6700/2080/ to be the min I consider.
Yes, its the original Geforce GTX Titan X (Maxwell based), I've not had any issues so far, its handled everything i've tried. Maybe not as good as some newer cards would and does not have the new features. 12gb is the main issue I think most new cards are 8GB, I was thinking 2080/6700/ 2070 Super or better.
Any Advice ? would it matter if I go AMD or Nvidia ?
I don't know if you like things in your ears but I found switching from headphones to in ear monitors(earphones) was like a whole new world!
Do you do anything other than gaming? If so, what kind of apps/usage?
Which games primarily?
Do you have any more niche plans, like using VR or running SteamOS?
Mostly movies, home office use, I have tried out local AI, No niche plans, but it always a good idea to have some flex, Last major game was Hogwarts legacy, GTA V. WWE 2k25, rest are older, I wanting to try the playstation game uncharted etc, but nothing new really catch's my eye anymore
Only if I have no option but I like over ear ones.
If you're serious about doing this then I'd look into it.
From what I'm aware and have seen of benchmarks (e.g. in THG's reviews), the differences can be stark, like a 5060 Ti 16GB beating a 9070 overall, even though it is a way slower card in raster.
Software used, driver version/support and APIs used are very important, since they can widen or close the gap between AMD/nvidia. VRAM is also king there, depending on what you're doing.
Just started trying it out, for now. but I would not invest in a GPU just for local AI yet.
