Looks awesome for what it is!
My big retro thing for the week was I unpacked all my SNES stuff the other day and cleaned it all with IPA. Took me hours as you'd probably expect of scrubbing to remove the years of dirt, permanent marker name tags on the top, general grime etc, most of the cartridges have discoloured at this point and some have stains in the plastic itself, but everything looks better and fresher and less grimy than it did, and given the grime off the contacts, I can't help but think they should read better. All 44 games worth of it
The downside was I went to test everything at the end of the day, I'd already sourced a TV with the appropriate connectors, only for my chinese aftermarket PSU to go pop almost immediately on powering up the console, so I've had to order another one before I can go through and retest everything. The PSU went pop pretty immediately so it was obviously on the edge after multiple years in storage, I doubt it's damaged anything, but still bloody annoying. On the plus side before the pop, the TV did switch into RGB SCART rather than SVideo mode, so it confirms at least one of the cables I had WAS an RGB SCART cable
What I will do when the new PSU comes as well, as this gave me time to think about it, is I'll use one of my cheapest cartridges as a cartridge slot cleaning tool to get some IPA into the actual cartridge slot in the console. Now I've seen the dirt off the carts, I can't imagine it won't help the console too (not sopping wet but a nicely IPA damp/wet connector into the cartridge slot 10-15 times to break down any gunk) and then let it dry before testing the machine and all the games
