Thanks yeah it was expensive kinda regret that one but it does look niceIts a nice machine, as mentioned there are places you could have saved money and not dropped any performance (GPU, RAM) and that is one expensive case
Enjoy it!
Yeah kinda over spent on the case lol but oc prices lol, I wouldn't say it's entry level with a x3d CPU and a 5070 GPU but that's me what parts would you have changed for better performance
I suppose that depends on settings and textures which going a little lower r isn't exactly making much difference that you can really tell
You don't have to justify your choices. Your money your problem.Mine was more built around a balanced setup for long term use rather than just chasing benchmark numbers.
Mainly cause I prefer Nvidia over and gpus it's just a personal preference like and vs Intel personal choice depending on what you want from your set up.Considering the 9070XT is equal to the 5070ti, why on earth consider the 5070???
Sorry but nvidia fanboyism is blinding you
Rate my build
Hi guys it sure if this is the correct place e to post this so apologies if it isnt Wondered if people could give me thoughts on my PC build I have done Case - Phanteks NV9 CPU - AMD Ryzen 7 7800X3D Eight Core 5.00GHz Board - Asus TUF GAMING B850-PLUS WIFI DDR5 ATX GPU - Asus GeForce RTX 5070...forums.overclockers.co.uk
16GB VRAM for 1440p panels is recommended, I already told you I've seen it at 14gb vram usage 1440p and that's with some RT, FG & scaling features disabled
but hey do whatever you want
More a discussion than a justification there is so many opinions on what works with what etc I can talk about PCs all daybYou don't have to justify your choices. Your money your problem.
Yeah tbf that build is probably more aimed at max fps per pound than overall system balance. If all someone cares about is squeezing the most gaming performance possible into a budget then fair enough the 9070 XT makes sense but I prefer Nvidia cards over and gpus
Mine was more built around a balanced setup for long term use rather than just chasing benchmark numbers. I’ve got better storage, better board, decent upgrade path and the 7800x3d is still one of the best gaming CPUs anyway especially for 1440p high refresh.
Not saying theirs is bad at all, it’s just a different way of spending the money really. More raw gpu focus where mine was more overall quality/future proofing.
And realistically the CPU difference is probably more like 5-15% depending on game/settings anyway, not some massive night and day jump. At 1440p with a 5070 the GPU is gonna become the limit in a lot of games before the CPU difference fully shows.
The 7800x3d is still top tier gaming wise, it’s not like I paired the 5070 with some budget CPU lol.
this is the only thing i'd change in that build.
300TBW for a 2TB SSD...basically ewaste
but yeah. OP's already bought and built that PC, no use crying over spilt milk.
we all think he's spent his money unwisely, but it's his money after all.
I get your point and if I was purely chasing max fps possible for the money then yeah obviously more of the budget would’ve gone into the GPU. I’m not denying a 5080 build is stronger in raw gaming performance.The "better storage" is debatable and dependent on use case, games wont care, likewise with the motherboard.
All white build with a 5080 for what you spent on a 7800X3D/5070:
My basket at OcUK:
- 1 x AMD Ryzen 7 9850X3D Eight Core 5.60GHz (Socket AM5) Processor - Retail (SKU: PRO-AMD-06938) = £399.95
- 1 x Crucial Pro 32GB (2x16GB) DDR5 PC5-44800C36 6000MHz Dual Channel Kit - White (SKU: MEM-CRU-03115) = £319.99
- 1 x Phanteks AMP GH 850W ATX 3.1 PCIe 5.1 80 Plus Gold Modular Power Supply - White (SKU: POW-PHK-02520) = £104.95
- 1 x Thermalright Aqua Elite 360 White ARGB V3 All In One CPU Cooler (SKU: COO-TLR-03257) = £39.95
- 1 x PHANTEKS XT M3 Micro-ATX Case, includes 3x 120mm Fans - White (SKU: CAS-PHK-05736) = £56.90
- 1 x Sapphire Pure B850M WiFi (Socket AM5) DDR5 Micro-ATX Motherboard (SKU: MOT-SPR-05691) = £129.95
- 1 x KIOXIA EXCERIA BASIC 2TB SSD NVME M.2 2280 PCIe 4.0 Solid State Drive (SKU: STO-KIO-07150) = £199.99
- 1 x Zotac GeForce RTX 5080 Solid OC White 16GB GDDR7 PCI-Express Graphics Card (SKU: GRA-ZTC-04789) = £1,199.99
- 1 x NVIDIA Game Bundle - 007 First Light (SKU: DIG-NVI-08114) = £0.00
Total: £2,463.66 (includes delivery: £11.98)
The above is superior to your build by every metric that matters, and it's still a lot of needless expenditure on aesthetics, as mentioned the white tax is real and you could easily shave a fair chunk of money off this and get identical performance.
You could also have easily fit in a 5070ti for a good £400 less not even including the other potential savings.
If you're happy with the build you've put together that's what matters, but it's really not the route I would recommend to anyone.
I think what's more baffling is that you didn't get an OLED monitor because you felt that the prices were ridiculous, but spent a huge amount of your budget on things that really do nothing to improve your actual gaming experience, you could easily have built a faster system and got an OLED monitor for around £1900-2400 all in.
i can assure you there were no corners cut (except for that SSD which was mistakenly specced as i pointed out earlier)cut corners elsewhere.
so tell me what can your asus board do that the sapphire pulse can't?Better board
a bit pointless nowadaysseparate windows/game drives, better SSD setup
errr, nobetter overall parts quality etc
but still matters to me day to day.
^Ok just enjoy it then
please educate me as to why a 9850x3d/5080 build is less balanced than a 7800x3d/5070 build because i struggle to see how this is exactly the caseYou’ve clearly prioritised max performance per £ more whereas I leaned a bit more into overall build balance/preferences.
^if your stuck in that way I can't help that
