Music production PC
13 Jun 2026
Basingstoke
Hi.
I'm looking for specific setup.
AMD Ryzen 9800x/9900x/9950x or similar but AM5 one. Minimum 32gb ddr5 cl30/32 fast nvme 1/2tb, min 850w psu gold. Good quiet (preferably water cooling depending on CPU) cooling. All in nice airy case. I need something I can expand in future. My budget is around £1k (can go higher for right set) and I don't mind used. No GPU really needed but I won't complain if it'll come with one. Does anyone selling?
£339 (incl. VAT)
£245 (incl. VAT)
£400 (incl. VAT)
£350 (incl. VAT)
£170 (incl. VAT)
£125 (incl. VAT)
£60 (incl. VAT)
£25 (incl. VAT)
£80 (incl. VAT)
£73 (incl. VAT)
min 850w psu gold
You're gimping your budget with this stipulation, if you've no need for a graphics card you don't need an 850W PSU.
The efficiency rating doesn't really mean much in the grand scheme of things either, you could have an absolutely terrible power supply with a gold rating and a fantastic one with a bronze or silver.
Are you certain Intel might not be better for your usage? While Ryzen is ahead in many respects, Intel is extremely competitive with the 270K which is the same price as the 9700X while performing around on par with the AMD 9950 depending on task.
Regardless, unless you're willing to build yourself you wont be getting what you want for a grand.
Closest that I can get, and I'd still lean toward a 270K over it depending on the software you use:
My basket at OcUK:
Total: £1,067.89 (includes delivery: £0.00)​
You could save on the NvME, the one I've included has DRAM which I suspect might benefit your use case, but if not you can knock off another £20-30.
My basket at OcUK:
You're a genius bro!
I like the specs and pairing. Perhaps you're right about the PSU. I was rather thinking about future needs rather than what I'm building now. Also however I'd like to keep the budget as close to 1k, I can push it bit further. If you'd be to propose some changes and upgrades I'd be grateful for recommendations. Perhaps update on SSD or ram, etc.
Also I'm not against the Intel it's just I don't want to buy anything / platform that approaches the end of life, also I wanted something versatile that can handle music production but can be used for gaming too (if needed) If there's a better option in "newish" Intel I'm open to it. And thank you. So far the best option that you proposed
What is the exact software you use for music production? If we knew we'd be able to better gauge whether a switch to Intel would be worth considering.
I do music production and my machine flies like poo off a shovel.
These are my main components:
Operating System
Windows 11 Pro 64-bit
CPU
Intel Core Ultra 7 265KIntel Core Ultra 7 265K
Arrow Lake Technology
RAM
63.0GB
Motherboard
Gigabyte Technology Co., Ltd. Z890 AORUS ELITE WIFI7 (U3E1) 28 °C
Graphics
BenQ GW2760HS (1920x1080@60Hz)
Intel Graphics (Gigabyte)
Storage
2794GB TOSHIBA DT01ACA300 (SATA ) 34 °C
2794GB TOSHIBA DT01ACA300 (SATA ) 33 °C
1863GB KINGSTON SFYRD2000G (SATA-2 (SSD))
Audio
Realtek High Definition Audio
I bought the Motherboard and Processor off an OCUK member then added this.
The ram prices changed quite a bit since then it's a powerful machine. But I'm thinking about the future upgrades. And if I can pull it for couple of hundreds difference it works out cheaper than replacing everything in the future. I've changed it twice already and even my current setup built on old i7 4790 is managing most of my tasks but the support for Windows 10 goes away and I'm tired thinking what caused the glitch , whether it's my pc, windows, old technology. If I'm about to spend money for new, different PC I want to make sure it'll be enough for years to come.
I'm using Ableton, cakewalk Sonar, and pro tools as DAWs than I'm using all sorts of plugins and VSTs, guitar effects chains and whatnot. I do live monitoring so low latency is important (stable good single core performance)
I'm pretty sure the system I have with that motherboard, CPU, SSD and memory is going to last a while.
When I load Cakewalk Sonar with about 200 plugins it takes seconds, my last system took a while and I had it from around 2007 (when the I7 was first released).
I also do a lot of AI Splitting and removing background noise and again compared to my last system with a normal I7 with 16gb this flies.
I use a lot of IK Multimedia plugins.
I time this at 10 seconds to load Cakewalk with around 200 plugins.
I was asked the other day to show off my new IK ToneX sounds and how they work in a DAW so did this quick video which is awful quality.
It looks good. It's stronger than the system I put together for my brother also on Intel 12600K and he never complained - he loves it. I just don't trust Intel updates. They tend to make great stuff and keep short support for it. AMD just looks slightly more reliable. And to build the system like yours it'd cost me nearly the same money especially with 64gb ddr5
Good music btw
I never do updates, for at least 3 decades I use the rule of "If it ain't broke don't fix it".
My last system from 2007 never got updated.
Then you will understand why longer, reliable support period is important for me... I need to dispose my old i7 despite it still working well. If I go new AM5 I have years of guaranteed support. Won't get it from Intel. Not for the same price
For music production you really need a GPU, it's do to with memory latency and shared memory. It does not have to be a powerful GPU, an entry level RTX will suffice.
I've been in one of the best mastering studies in the UK and had this exact conversation, the studio always uses a GPU in the machines.
It doesn't make a lot of sense. I'm going without GPU in music production for years. Ram and CPU is the key. Some plugins and effects (like cab mirroring) are using resources of GPU to build it quicker but it's not a majorly draw resource.
It's not the plug-in's as such, but yes the GPU can help with those.
The issue is shared memory being used for GPU as it effects clock timings and general smoothness of the computer. The studio I've had this conversation always had their machines custom build by a company who specialised in music production computers, and the recommendation was always use a GPU. This recommendation is going back 20 years long before GPU's could process the plug-ins.
Try first with the on-board graphics, however I'm relaying on here what I've had discussions about.
None of this applies to me, the verdict at the bottom does
For the vast majority of music producers, the Graphics Processing Unit (GPU) is one of the least critical components in a PC or Mac build.
While a powerful processor (CPU) and plenty of RAM are the absolute workhorses of an audio workstation, the graphics card plays a very specific, limited role.
The Standard Rule: Integrated Graphics are Usually Enough
If you are buying a standard laptop or building a desktop for music production, the integrated graphics built directly into your CPU (such as Intel Iris Xe, AMD Radeon Graphics, or the unified GPU inside Apple Silicon M-series chips) are more than capable.
Audio processing is almost entirely a sequential mathematical task, which means your CPU handles 99% of the heavy lifting when calculating audio effects, virtual instruments (VSTs), and track routing.
When Does a GPU Actually Matter for Audio?
While you don't need a high-end gaming card, there are a few specific scenarios where having a dedicated GPU—or at least a competent integrated one—becomes important:
1. High-Resolution or Multi-Monitor Setups
If you run a professional studio layout with two or three monitors to keep your arrangement view, mixer window, and plugins open simultaneously, your GPU has to drive those pixels. A weak or outdated integrated GPU might struggle to render smooth animations across multiple 4K displays, causing visible stuttering or lag when moving windows around.
2. Modern "GPU-Accelerated" Plugins
Many modern Digital Audio Workstations (DAWs) like Ableton Live, FL Studio, and Pro Tools, alongside plugin manufacturers like FabFilter, Serum, and Soothe2, use GPU acceleration.
  • This means they hand off the rendering of their sleek, highly visual user interfaces (like real-time spectrum analyzers, 3D wavetables, and moving vectors) to the graphics processor.
  • Why it matters: Offloading the visual interface to the GPU keeps your CPU completely free to focus strictly on processing the audio without stuttering.
3. Neural Network and AI-Powered Audio Tools
The landscape of music production is shifting to include AI processing, such as stem separation tools (e.g., separating a song into vocals, drums, and bass), automated mastering, and neural amp modelers (like NAM or IK Multimedia's TONEX).
  • AI data models rely heavily on the parallel processing architecture found in GPUs.
  • While these tools can run on a CPU, having a dedicated GPU (especially one with NVIDIA CUDA cores) can speed up stem extraction or neural training from hours to mere seconds.
4. Hybrid Audio/Video Creators
If your music production workflow includes editing your own music videos, scoring films, streaming your studio sessions on Twitch, or creating content for YouTube, video editing software (like DaVinci Resolve or Premiere Pro) demands a powerful dedicated GPU.
The Hidden Danger of High-End GPUs: Fan Noise and DPC Latency
Ironically, buying a massive, high-end gaming GPU can sometimes harm a music production environment in two ways:
  • Acoustic Noise: Powerful GPUs require large, loud cooling fans. If you are recording vocals or acoustic instruments in the same room as your PC, a loud graphics card can easily ruin a take.
  • DPC Latency (Audio Dropouts): Graphics card drivers (particularly NVIDIA's GeForce drivers) are notorious causes of Deferred Procedure Call (DPC) latency. If a graphics driver hogs the system's attention for a fraction of a millisecond too long, it causes your audio buffer to empty before the CPU can refill it, resulting in annoying clicks, pops, and audio dropouts in your DAW.
The Verdict
Allocate the bulk of your budget toward a high-tier CPU (prioritizing strong single-core performance) and at least 16 GB to 32 GB of RAM. Unless you are heavily utilizing AI audio modeling or editing high-resolution video alongside your music, a basic dedicated graphics card or modern integrated graphics will do the job perfectly.
The Verdict
Fully agree with it. I'd just add that currently only the capturing the sound of an amp onto the tonex is the only scenario where I'd really utilise my GPU. I don't think that's critical for my setup and needs. I think integrated GPU of 9900x/9950x will do just fine.
Do you have ToneX stuff?
