Anyone else having issues with Amazon Echos. I use them to announce when things like the washing machine are finished and they keep becoming unavailable.
Looks like it might be a common issue so hopefully it gets fixed.
Alexa Devices integration periodically becomes unavailable with CannotRetrieveData('Request failed: Service Unavailable') until integration is reloaded · Issue #174990 · home-assistant/core
The problem Alexa Devices Integration - Periodic "Service Unavailable" / Integration Becomes Unavailable Environment Home Assistant Core: 2026.6.4 Installation: Home Assistant OS (x86-64) Alexa Dev...github.com
Whatever hardware you go for, what’s stopping you plugging it in next to your router? Running HA on a WiFi connected device isn’t a good idea.Noob here and I'm thinking of using Home Assistant and have a few Reolink poe cameras. I was thinking of using a tablet for the HA dash (will add a few devices and widgets? to it) and view the cameras, have alert setup as well. Can the screen be on sleep and turn on when there is doorbell activity?
Now my router is upstairs and I'm thinking of mounting the tablet downstairs on the wall. I have read about HA green, can it work with a WiFi dongle? I don't want to have a long ethernet wire running nor want to use homeplugs.
Will this work?
Did some reading and just ordered a Dell Wyse 5070 J5005 for £43, was last one. Should be good right?I wouldn't go buying a HA green - just get a Rasp PI it's incredibly easy to get started.... Customising it is where it get exciting!
One of the reasons is because that corner of the house is a mess with ethernets from cameras, Poe switch, router, ont then HA client. I was thinking with the client downstairs and closer to the tablet, it would be more responsive when showing camera feed?Whatever hardware you go for, what’s stopping you plugging it in next to your router? Running HA on a WiFi connected device isn’t a good idea.
Putting the tablet to sleep and activating on a doorbell ring can be done. I haven’t tried recently but I spent a lot of time trying to get such a set up to work and had to give up. It may be simpler now but be aware it may be fiddly.
It’s about reliability and a hard wired connection is more reliable than WiFi. Responsiveness shouldn’t be an issue. If you get good WiFi where the tablet is then you’ll be fine.One of the reasons is because that corner of the house is a mess with ethernets from cameras, Poe switch, router, ont then HA client. I was thinking with the client downstairs and closer to the tablet, it would be more responsive when showing camera feed?
Ok so the Wyse I bought doesn't have the WiFi card. Does that mean of connected to the router by ethernet, HA can connect to compatible devices?It’s about reliability and a hard wired connection is more reliable than WiFi. Responsiveness shouldn’t be an issue. If you get good WiFi where the tablet is then you’ll be fine.
Yes. Absolutely. Just a check here - you do know that HA is a server product and that you don’t connect a screen to the HA device to interact with it? I just get the impression that’s what you’re expecting and it’s a common expectation!Ok so the Wyse I bought doesn't have the WiFi card. Does that mean of connected to the router by ethernet, HA can connect to compatible devices?
Wasn't too sure about connecting a screen directly to it. I heard about HA from my friend a few months ago and only yesterday watched several videos, read a few Reddit posts and decided to take a dive.Yes. Absolutely. Just a check here - you do know that HA is a server product and that you don’t connect a screen to the HA device to interact with it? I just get the impression that’s what you’re expecting and it’s a common expectation!
You'll use a separate phone, tablet or a computer to access the GUI which will guide you through the set up process. I've been running HA for so long that I can't actually remember how the install and set up process works anymore! There will be an online guide somewhere, most likely on the Home Assistant website which will be more help than anything I type. Once you've got HA installed, you'll set up the cameras and lights and then move on to making up your dashboard. What cameras and lights do you have btw?So once I flash it, I need to access a web gui for the initial setup. After that I can get a tablet or 2 and setup the dashboard where I can access my cameras and control lights?
What's the minimum storage required for HA OS? My friend is telling me to install Ubuntu and use docker. Haven't read up about docker.
Reolink cams, Xiaomi and meorss lights. Will be adding a few more lights. My boiler (heater) control is wireless, not sure how it connects as I can remove it from the mount use it upstairs. I'm hoping that can be added as well. Planning to buy and mount a tablet downstairs so can control lights and see camera when someone's at the door.What cameras and lights do you have btw?
I went the VM route and it was incredibly easy to get up and running. Windows 11 as my OS because I couldn't be bothered learning Linux. I then also have Plex running.Wasn't too sure about connecting a screen directly to it. I heard about HA from my friend a few months ago and only yesterday watched several videos, read a few Reddit posts and decided to take a dive.
All that kit should be picked up by HA with minimal effort. I take it the Xiaomi and Meross lights are WiFi?Reolink cams, Xiaomi and meorss lights. Will be adding a few more lights. My boiler (heater) control is wireless, not sure how it connects as I can remove it from the mount use it upstairs. I'm hoping that can be added as well. Planning to buy and mount a tablet downstairs so can control lights and see camera when someone's at the door.
