Is it just backing up HA settings and layout?It’ll be fine. Just remember to backup on a separate disk
i have this https://www.amazon.co.uk/dp/B0FDB51..._5&=&crid=1VI6BC7J5HKVR&sprefix=apolo&th=1So who's using a tablet mounted on a wall?
Since the latest update it's been faultless.I had nothing but problems when I tried to get that integration working some time ago so instead I use Alexa Media Player. It may be worth checking that out to get the notifications working whilst the other integration is fixed.
How's the battery life?i have this https://www.amazon.co.uk/dp/B0FDB51..._5&=&crid=1VI6BC7J5HKVR&sprefix=apolo&th=1
mounted on the wall - basically its a calendar, but runs android so has the app installed. if i could get a nicer layout for the calendar (to match the android widgets), i would have the ha front and centre
Just ordered a tablet earlier today, maybe I'm getting carried away. I'm also looking to buy smart blinds and a few bulbs.Build the dashboards in the web browser on your laptop, then when you have a tablet for displaying you set the home page to the specific URL of the dashboard and use controls to hide the sidebar, etc
Edit: or you can use the app!
Those Aliexpress bulbs are Zigbee. To use them with HA you need a Zigbee dongle such as an SMLight SLZB 06. I'd also caution against buying cheap. I'm not saying the cheap stuff won't work but low quality components can cause problems further down the line.Just ordered a tablet earlier today, maybe I'm getting carried away. I'm also looking to buy smart blinds and a few bulbs.
My Yeelight was added to HA with no issues but the Meross bulb doesn't. Wondering if this will work. https://a.aliexpress.com/_EuVjaiK or Tapo L530B which I've seen on marketplace for a decent price.
Thanks but hue is a bit too expensive. Interestingly my Yeelight which is more than 5 years old was picked up on HA and I can also change the colours on it. Just trying to figure out if Tapo would be the same as price isn't too bad.For a Zigbee dongle I wouldn’t cheap out and recommend either one from SMLight or Nabu Casa, the HA developers. A dodgy dongle will just your life hell!
If you’re just playing about and finding your feet then find a bulb that works with Tuya. They come in WiFi and Zigbee flavours so watch what you buy. Personally, I’d skip the WiFi bulbs, get a good Zigbee dongle and pick up a couple of Hue Ambient bulbs. They’re not cheap by any standard but they’re good, natively supported and last for years.
