recover a deleted partition?
9 Aug 2013
S. Wales
so when reinstalling windows i deleted my ssd i keep all my stuff on by mistake, all my photos,videos of my kids/cars etc etc.
is it possible to just recover the whole partition or do i need to recover all files then format to reallocate. im not exactly pc smart, cant find any freeware that will recover large files either free or small charge
TestDisk is probably the best FOSS tool for the job
E: snap as above
If you only have one copy of any file, you may as well delete it ASAP to save the grief down the line
@MCFC_ANDY
I have recovered partitions and files with testdisk before and works well and free. Just make sure to read the links below and see how you get along.
https://www.cgsecurity.org/testdisk_doc/
For a paid version I recommend Disk Drill, also a free version but won't allow lots of files recovered for free, unless you pay but works well too and easier to use.
i tried the suggested, but in end the easiest i found was minitool, not sure how but it allowed me to recover everything without paying strangely, mate sent me a copy, the others suggested had limitations
as long as you don't overwrite it
or format it by means
that do a secure erase on it
the data is still there just it's position is
marked as ready to write new data on
have even recovered data after windows
was installed on it
though didn't recover 100% in that one
I would take it as a timely reminder
if something is irreplaceable
make multiple backups of it before
disaster strikes
learnt my lesson
luckily it worked out ok for you
got 5 x M2 and 4 x sata ssds plus external drives
so I know how easy it is
to accidentally format the wrong drive :cry:
I am OTT about back ups
but got all the drives when prices were
rock bottom
so would rather have too many back ups
than not enough
plus the 2.5 ssds can be isolated from the system
as another fall back
just power them on now and then
to prevent bit rot
I was very concerned to read this thread before you'd recovered it, and am very relieved and pleased for you that you successfully got it all back! Jolly good show.
i have quite a few drives internal and external, i was deleting partitions to reinstall windows, something ive done a million times, but didnt noticed it jumped to my back up drive, so didnt look and bang one deleted back up drive. doh. as u say easily done
Did this exact same thing before, Testdisk recovered the partition.
Since that I remove all other drives when installing Windows!
I used to just hoik out the sata cables of the other drives leaving just the boot drive, thats not so straightforward with NVMe anymore!
Or just disable the individual sata ports
In the bios
And yeah can only get to 2 of
My 5 nvme drives due to
The watercooling loop
Being able to disable individual nvme drives
In the bios would be great
