- 19 Oct 2002
- Shakespeare’s County
What’s it’s gonna be on when you get back to it though?Meanwhile my car is currently at Gatwick airport with 61% charge a projected range of 263 miles.
I've never been under any illusion that spending more necessarily gets anyone a better service, my point was people need to complain and not allow businesses to set their own agenda when it comes to dealing with these customer service complaints.People say about expecting good service when buying a car as it is the "second most expensive thing you will ever buy", I was just pointing out that you can't necessarily expect better for the most expensive thing you will ever
People can also be excused to think that buying new = no issues. It absolutely should, but the reality, just as it is with many cars, is that this simply isn't the case.
Phantom drain? None that I am aware of.What’s it’s gonna be on when you get back to it though?![]()
, that's not too shabby for a heavy vehicle.which motor the 200bhp or mythical 280bhp/ap550 ?Decent efficiency again over the past couple of months in the ID4.
My trips to Slough and back from Derby each week are now getting me around 3.8-4m/kwh
So, here’s a fun one: we came away on holiday last week to a house in Cumbria for a family get together. From Cheltenham it’s just over 200 miles, plus another 20 to join up with the folks near Preston. In the current weather, just about doable in the OH’s EQC. Add in a car full of stuff, toddler’s toys and roof box and it starts to get a bit hit and miss!
I’m a firm believer in charging when you can and not when you need to, so I was never going to risk it and knowing there wasn’t charging available at the property we pulled into Keele services and stuck it on charge.
Well, I attempted to - the Gridserve refused to connect and the Tesla next to me wasn’t having much luck either so we gave up and went ten miles north to try again.
Lots more chargers, several in use so I was confident of getting some electrons - 5 chargers later and absolutely nothing, either failure to connect or a brief charge and then stopping again 5 seconds later. It left a brief niggle of “is it me?” in my head…
The boy needed his nap and I knew there was good chargers near my parents that used before so we carried on up to the M55 and I dropped them off to go and try my luck. Another 6 chargers later and I now knew the car was the problem, with an occasional red charging lock indicator around the plug and exclamation on the dash but not much else. Having seen these before a few times in the last couple of weeks but having had no issues AC charging my head turned to a problem in the DC system and I started making calls to the local MB dealerships as I was sat on 18% and at the start of a holiday.
Both local ones in Blackpool and Preston robbed me off and refused to look at it that day or even get back to me at all, and the local independant couldn’t do EV work that deep, which left me in a bit of a pickle and thinking of all sorts of scenarios with hire cars and recovery trucks etc.
Then had a lightbulb moment (no, not @danlightbulb) and figured that the AC charging had worked that night before I left, so why wouldn’t it be working now? Zapmap found me a 22kW charger less than a mile away and when I plugged in the car was taking the full 11kW quite happily, so I sat the for an hour till I had enough range to get to our holiday home (plus a buffer), picked up the family and then went full EVangelist sitting at 50-60mph behind a lorry all the way up the M6
Charged it locally on some public AC in the Lakes and we haven’t done much driving here anyway so I can get home no problem and it’s booked in to the MB garage down there to figure out what part of the DC system is knackered.
Just to follow this up, the local MB dealership took the car in this week and diagnosed a thermal cutout switch in the charging socket as knackered, so the car was thinking it was overheating constantly and not allowing the charge.
Total cost to replace - £2200.
This is plainly ridiculous, and without even asking they’d gone to MB asking for a goodwill gesture due to it being a 72 plate on 27k miles, and it brought the price down to £850. Drive a Mercedes, pay Mercedes prices!
As an aside, we’d seen they had charged it on AC through the app, but not on DC. When this was questioned on the phone after being told it was ready, the rep pushed back but eventually went and asked the tech who said they don’t have DC charging facilities there which boggles the mind slightly. Tried it on the way home and it worked fine.
Had them do a battery check - 98.7% which doesn’t seem too shabby.
Oh really? I have Ohme Pro, in what way did it not work out for you then?Got my new EV charger at my new place. It’s really nice and just works.
Really simple - you set the start time and end time, and it just works. Much easier than Ohme.
Only £350 plus install too.
So did they replace the entire (N293) harness, or just the socket assembly? I know the sensors are inline, so I assume they would need to fit an entire new harness, but then even at £2,200 that doesn't sound right given the labour involved.
I guarantee that the actual sensor didn't cost more than £50, and even that's being generous.
Probably. Long gone are the days of me fixing my own cars, mainly due to it being a Mercedes and an EV.
I am NOT touching that stuff.
this you?
It's an inline sensor AFAIK so the DC socket and harness need to be changed as you can't just change the sensor.I guarantee that the actual sensor didn't cost more than £50, and even that's being generous.
Labour and materials not including the ev charger 1 450.00
HYPERVOL T PRO 5m 1 520.00
Total 20% VAT 194.00
Total GBP 1,164.00
Zappi 7.4KW Tethered EV Charger 1 590.00
Total 20% VAT 208.00
Total GBP 1,248.00
Blind the battery to the charger. It’s always cheap between 11.30 and 5.30 the charge it up. Car charging slots outside of this are a bonus.2 quotes for EV charger installs. Leaning towards the Hyperbolt, but saying that I don't think my Fox EP12 batter is compatible with a smart tariff so I'm currently charging it on Octopus Go (non-intelligence). I'm not sure how it would work if I switched to IOG with my battery not being able to be aware of the charging slot.
Octopus are launching a charger+ battery tariff soon, is fox not in the list for that also?
Edit: https://octopus.energy/help-and-faqs/articles/charge-pack/
If you don’t want to get into home assistant, the above is worth it.
Looks like you bolted a toilet bowl to the front of your houseZappi
