My first Amiga 500
23 Mar 2004
Yorkshire
So I got my first Amiga delivered yesterday.
I have a few Amiga memories from when I was younger. My cousins had an Amiga which I remember playing Lemmings on and a couple of friends had them too and I remember Monkey Island, Sensi and a few other games. I recall Walker running on an Amiga in somewhere like Currys or PC World (maybe Dixons) which always blew me away.
I went from Spectrum to consoles and then to a 486 so never had my own but I've always had a bit of a soft spot for the Amiga and I've been wanting to get one for a while.
Emulation is great and all but there's something about the original machine that has always fascinated me.
The listing said that it had been power cycled, but it hadn't been properly tested beyond that. I didn't actually pay enough attention to that distinction until after I'd won the auction.
It came with the Amiga 500 itself, the power supply, tank mouse. some cables and a rather manky-looking, well-used joystick.
The Amiga itself looks to be in really nice condition. It's obviously quite yellowed, as you'd expect after 30+ years, but the warranty seals were still intact, so it looks as though it may never have been opened.
I checked the trapdoor underneath, hoping there might be a RAM expansion lurking in there, but unfortunately there wasn't one.
I'd heard horror stories about leaky batteries and capacitors so first job was to open it up and take a look.
I'm really impressed by how clean the motherboard is. There's no obvious corrosion or damage, and there isn't a battery/RTC circuit to worry about on this particular board from what I read so thankfully there's no battery leakage to deal with either.
The capacitors don't show any obvious signs of trouble, although unless they were leaking or charred I probably wouldn't know any better.
The power supply is another matter. The one that came with it is dated 1990, so it's obviously getting on a bit. I'm a little wary of plugging a really old PSU into the Amiga without being able to check its output first. I don't have a multimeter, so I'm going to have to work out the safest way of approaching that, any thoughts or should I just invest in a new one regardless?
Apparently the seller did power-cycle it, so at least it has presumably been switched on relatively recently, but I'd still rather not just blindly plug it in and hope for the best.
I also don't currently have any Workbench disks. I have previously bought Amiga Essentials on Android which includes ROM/Kickstart files, but I'm not sure whether there's any practical way for me to get what I need from that onto a physical Amiga floppy.
It looks like Cloanto sell Workbench disk sets, so that's one possibility.
I've included the motherboard photos because I'm interested to see what people can identify from it. I'm particularly interested in the board revision, chips, and anything else that might be unusual or noteworthy about this particular machine. I ran them through ChatGPT but it kept giving me conflicting and wrong information or making up stuff like it has Rev 5 printed on the board when it clearly doesn't.
I'm very much a newcomer to owning an Amiga rather than an expert, so I'm looking forward to learning about it, and hopefully getting it up and running.
It looks like a 6A board to me. If you remove the FDD you'll see another label that will have the revision on it.
It's the 500+ that has the RTC and so a potential Varta battery leak, the 500 is generally safe unless an expansion card has been left in that then leaks.
The 500 and 500+ are generally 'fine' from a leaking cap point of view too - it's the SMD mounted caps in the 600/1200 that are a concern.
The PSU is probably fine too. Not a great deal to go wrong inside them (assuming it's a big heavy one) but there are modern options. I would stay clear of PowerShark, it's overpriced imo and it requires a USB-C PSU that is of a long obsolete spec, as it simply passes though that PD voltage.. despite it being an optional voltage and having been that way in the spec for 10 years.. weird design choice!
Have you look at Goteks, for loading disk images via USB instead? There's also the likes of PiStorm, and RGB2HDMI..
:D
There's a very active Discord on RetroCollective and that has an Amiga channel - I'm very much a newbie compared to some of them!
:D
Thanks for the info, will check out the Discord.
I got it from the British Heart Foundation via eBay and as it was pat tested I thought I'd give it a go...
Connected the 520 box and then RF into my TV, did a channel search... It's alive!
Now I need a workbench disk, I actually have an official adf of 1.3 as I bought Amiga Forever a few years ago and that was included.
But how can I get this onto an Amiga floppy? I have a PC but no floppy drive, obviously could buy one but would it support Amiga disks? Probably just cheaper to buy the physical disks from Cloanto?
I'll probably go with a pistorm at some point as that looks to be a great all in one solution and reasonable price.
For now I just want to be able check if it's working and I can use it stock. I'd love to get a replacement case but A1200.net don't have the original colour available and that's what I'd really want.
Picked up a couple of Amiga magazines from a retro gaming store in York (Sore Thumbs) which have the cover disks so will give them a go later and see if the floppy drive reads them (fingers crossed).
Edit:
The disks didn't load but I was able to get an error screen to show which allowed me to test the mouse is working so that's a result.
I have a working copy of Workbench 1.3 on the way so if that boots great, if not then the floppy drive might need a clean or replacing, will see.
Jealousy! I have deep regrets about getting rid of my childhood Amiga 600. I just never thought it would be needed again, but nostalgia is a powerful force. :D
Congratulations on the 500!
I feel you, Spectrum, Amstrad 464, Game Gear, Mega Drive, NES, N64... The list of consoles I flogged or gave away goes on and on, it pains me as I kept everything mint as well.
Workbench 1.3 disk arrived today and the Amiga booted it fine, bit noisy but I love hearing the sound of the floppy drive, so nostalgic.
Besides needing a deep clean the a500 seems in good working order which is great news.
I need a screen though, running off a massive telly ain't gonna work. The Commodore CRTs are pretty pricey so I might try and find a cheap 4:3 LCD for now.
If going for LCD, be sure to get on that outputs correctly (15khz)
I had a Benq BL912
Great result getting Workbench booting from a known working disk. Must be a relief after those magazine disks made the drive look suspect.
Yeah it was mate, although I probably won't be looking to use the floppy as a long term solution.
I picked up an OSSC as this seemed the easiest way to get my Amiga working with more modern screens.
I don't have the room for a CRT and until I can pick up a bargain priced 4:3 LCD I can use my existing equipment.
Only dabbled with with the OSSC briefly but was simple to use and the output seemed good. Lots of settings and scan line options but haven't had chance to play with it much.
I have a half mb trapdoor expansion on the way, plus a replacement case for the mouse from A1200.net. If the mouse is decent I'd like to replace the full case but thought this was an affordable way of checking out the quality from these guys before committing a bigger chunk of cash.
I have also been looking at a Go Drive Pro and think this will be a great option as I'll still have the option of using the floppy drive.
The one thing to note is a lot of the old Amigas suffer from leaky capacitors and will need recapping if it hasn't been done already and yes replace the PSU as well.
I had an A1200 back in the day ans loved it to bits, I was gutted reading about Commando going out of business (you could write a DbA in Corporate mismanagement, corruption and nepotism based solely on how Commodore was run, so frustrating and sad what upper management did to that company) but kept with it until 1998 when we got a PC. I really wish I had kept my A1200, so many enthusiasts have pumped them out with accelerator boards, extra ram and additional graphics chips and there's still people developing the original o/s and writing new games and software for the platform.
Supposedly the 500 is less prone to leaky capacitors due to the type, not sure how true that is but I think I will probably get it done anyway at some point.
So I am up and running, playing Lemmings on an original Amiga 500... Man it plays great with this old tank mouse.
The Mister is great and all but this feels so awesome.
  • Love
Reactions: GeX
It's 100% accurate. It's the 600/1200 that suffer with leaky caps. They differ from the A500 as they use SMD caps vs through hole for the A500. I'm not really aware of any big leak issues on the A500, and they're only changed if issues are seen with video / audio or stability issues. (It's just the battery leak on the A500+ that's a concern).
Ordered a Go Drive Pro, glad my floppy drive works but don't want to be entirely reliant on this. Will report back once I've got this installed.
I have an Amiga 500 and Amiga 1200, with the Amiga 1200 having a Pistorm ;) - I too have a powershark with a seperate modified power supply as well for the A500. If he does buy a powershark power supply, I can tell him exactly what USB-C charger and cable he needs.
The Amiga 500/Amiga 1200 Power Supply ( Your best going for something like this, it isnt cheap but will power everything including power storms )
As for the Powershark USBC Charger
UGREEN Nexode 65W USB C Plug, 3-Port Foldable GaN Fast Travel Charger​
Thanks for that mate.
