AM4 DDR4 is 16gb enough?
los
los
26 Jun 2011
Great Yarmouth
As the title, is 16gb of RAM enough for gaming at 1080p?
I've got a Ryzen 5 5600, unsure on what GPU yet. Just in general, wondered if I needed to be thinking about upgrading the RAM as well
It'll almost certainly be fine for purely gaming. Get it, find out the spec and try it out.
In the current market 32GB of DDR4 isn't cheap.
what are the other specs and how much are you paying for the rig?
for example, 16gb with a 3600 is acceptable, 16gb with a 5800x3d is less than optimal
16gb is borderline, but in these times of inflated pricing...will just have to make do
I don't know yet, it will probably be a 5500 or 5600x. I'm trying to do it cheapish, its a bang for buck rig shall we say. I'll spend the bit extra on the bits that are worth it.
Which is what I'm trying to work out currently, as I've been out of it for a while.
Then 16GB is fine. If your board has only two slots then I would even venture to say get a single 16GB stick of some well-known, easy-to-find ram that you can pair up later for 32GB, but that's even more of a "take a hit now for a better deal later".
I don't know the specs yet as I haven't got it other than it being AM4. Just in general, wondered if I needed to be thinking about upgrading the RAM as well
its fine. also you can pick up another 16gb 2nd hand pretty cheap.
Using utils like shutup10++ and winhance to get rid of windows 11 bloat and spyware will save you lots of RAM.
Are you doing this bit by bit, starting with nothing, or simply looking for a good gaming experience for as little as possible?
Do you need WiFi? If not the Sapphire B550 is only £80.
You could go with the Ryzen 5 3600 at £55 second hand from a well known second hand High Street retailer. Comes with a guarantee. It's on par with the 5500
I've got an old pc I had connected to the TV, changed the processor to a 5600, now going to get a GPU a do a gaming PC for my daughter
I was aiming up to about £150 second hand. But depends what comes along I guess
I'm running 16GB and it does me ok. 32GB would be better in some scenarios but if you're constrained by budget then 16GB will absolutely be fine.
13600K and a RTX 4070.. What I was doing was exiting all program's and end task the firefox process (would also do the same with if using any browser) as I have a lot of tabs open that would eventually hit 9-12GB and a couple of GB of VRAM usage and not doing this would cause longer loading times and potentially some stuttering issues at the start of gameplay with 16GB of RAM.
Upgrading to 32GB a year or 2 back saw a massive improvement in loading times and that was Final Fantasy 16 and Star Wars Jedi Survivor and the gameplay off both seemed a bit smoother but I did not do extensive testing to confirm this. As other's have said you may have an issue but it will be fine.
