City Fibre
If every provider supplies the same router then what position does the company manufacturing that router now enjoy?
How does having to supply a top end device to someone ordering a 100Mbps fibre service to use in a one-bed flat reduce prices?
What if an ISP wanted to launch a 25Gbps product on 50G-PON, are they not allowed to provide a suitable router and instead need to tell subscribers to buy their own? Or would every ISP have to shift to something with SFP28 interfaces?
I care far more about some ISPs locking their service down so that it can only be used with their router than I care about getting a device from the ISP that stays in its box and is returned when I stop using the service. My current provider didn't give me a router which is also fine. In an ideal world I'd like everyone to be able to opt out of having an ISP-supplied router but I can also appreciate if Plusnet had an option in the checkout for "bring your own router, -£2, click here to get an understanding of what this means" then a huge number of people will just see the chance to save £2, not read it, assume their Virgin Media Hub was a suitable device, and then take up loads of staff time with support and complaints.
I didn't say every provider had to provide a router I said the ones that do and the same with it does not have to be one company manufacturing it.
Big providers in this country give people for equipment wise using BT for example doesnt matter which package you have you get the same router. (They have different models because of the revisions they have gone through and plusnet ones are same ones but in different casing/firmware look)
If a person wants a different router with latest tech they can go buy it no different to now why should ISP provide it.
The last part is what I said they should not be allowed to lock them to only there network and 0 reason for custom firmware (This is the same nonsense mobile networks used to do with locked phones)
VM you don't own the equipment anyway it's rented to you.
I don't see what problem this would be aiming to solve. Your proposal is that ISPs that want to provide a router have to supply a standard one that works with all the products that those ISPs offer, but it can be manufactured by anybody so those ISPs now have to collaborate on maintaining a shared specification and software build, with every change to add an interface or move to a new Wi-Fi spec having to happen with agreement of the other ISPs in that group.
Meanwhile a provider that wants to launch a halo product like an 8Gbps service with whole-home Wi-Fi and 5G failover (the most profitable offering that any ISP has) can't give the subscriber the hardware needed to ensure this works on day 1 out of the box, but instead can recommend £400+ of equipment to buy from TP Link, Netgear etc?
I can't help but remember the episode of the Simpsons where Homer builds his ideal car that nobody else would want or buy, and bankrupts his long lost brother :D
Joking aside, I still having issues with CF/Zen, my ONT was replaced with a later hardware revision of Nokia XGPON after ongoing and worsening drops, previous ONT showed minor signs of casing warp on the back due to heat, but nothing significant, I hoped I had just been unlucky, and for a few days we had very few issues. Then they came back. ONT goes into a boot loop, sometimes it will come back within a few minutes, sometimes it won't, and I have to log the fault with Zen. We go through the same frontline faults process each time, despite having it in writing from the core team (2nd line) that it's not required, but the only way to progress it is to go through the motions of asgreeing a tech visit so it can be passed over to the core team who then - usually - realise it doesn't require a tech visit, and pass it over to CF, who manually push a profile to the ONT and we are up and running again, at least until the ONT decides to try to pull a fresh config however many days/weeks later. We also seem to have random short term losses of connectivity, ranging from a few secconds upwards that don't require me to log a fault. I've just pulled the last 30 days logs, and this has happened 35 times over that period, lasting anyhting fro 5 secconds - i'd only know from the logs - upto 6hrs+ when a fault needs to be logged. CF have tested the fiber twice in the last 30 days and pronounced it to be within spec each time, the ONT has been replaced, my logic is if they can manually push a config and it works, it's a CF network side issue, and Zen have reluctantly agreed, and as I now have two tech visits in 30 days it can be escilated when it goes down again.
This all started in January when I was migrated to Zen, I ended up with the Nokia upload profile issue initially and it took them a while to resolve, and my upload has been fine since, but since the fix for that in March?, stability has been a significant annoyance. I'm also loathed to migrate providers as finally someone at Zen has taken ownership, and I would prefer not to drop this on another ISP just to try and get a fix without making it clear what I was dumping on them, and my only other viable option is HFC, which won't be migrated to FTTP for years at this point, but for all it's inherant limitations, was at least reliable. As to the obvious question about fail over, my 4G failover set-up is currently running connectivity for a property awaiting OR fiber so I can view CCTV feeds and be annoyed by random foxes and badgers. I will be visiting the 5G thread shortly to sort a replacement 5G router that supports bridge mode :(
Any suggestions welcome, other than perhaps waiting for the great router of the people to fix this :D
I have no recommendation for your situation but I am in the vague orbit of 3 CityFibre connections on Nokia ONTs (Aquiss x2, IDNet) and they don't have any of those problems.
Yeah I’m in Nottingham and outside of the upload profile issue my connection has been stable other than I think 2 minor outages, that was on IDNet and now Aquiss.
Quick update, it's been fine for 24hrs - other than the testing - and the latest lot of contract techs mentioned they had a similar job at another property on the street, it had to be passed to a CF network tech to resolve as it was a cabinet issue, but they don't know what the outcome was. It at least gives me something to go on if (lets be honest, when) it goes down again. Obviously Zen would have no way of knowing this unless the other property is a Zen customer and the odds of them linking two faults on the same street anyway are low.
By "cabinet issue" I assume it's the OLT and you're on the same PON as the other person having problems.
Thought provoking point. I'm not familiar with CF's normal topology beyond the basics, the FEx is a few miles away where I used to live, they installed it right after I moved (along with VM fiber and OR), I had always presumed the primary node for the estate was elsewhere on the estate, and the smaller single street cabinet was the secondary node containing multiple POS that fed the individual TB for each property, but I come from an HFC background where cab, pit/bomb, T/TB is pretty standard across most franchises, so perhaps I am wrong? However, when they laid the fiber, I also remember them putting in a chamber furter up and taking multiple feeds across the top access road for the estate to feed the properties on that side and it's direct to TB, so logically the POS would be in the chamber, and we don't have a chamber/everything goes back to the cab. Either way, all I got from the tech's was a suggestion that it was a 'cabinet issue' and they have no mechanism to pass it for investigation by a network tech at this stage.
Sky doing 5Gb for £35 for Black Friday apparently.
They did a decent deal last year if memory serves, especially combined with Quidco/TCB.
Side note: My previously up/down every 24-48hrs connection is now back to being rock solid after Zen pushing CF to investigate following my complaint. Clearly whatever it was that caused the issue was addressable by CF beyond the property line.
Anyone experiance thier download speed tank last night? I'm on no one (Home Telecome) and my downloads are hitting 5/10Mbps and i'm on 900/900. I put it down to GTA6. I checked this morning and it hasn't resolved.
The last test i did was this morning at 4.28, the same speed and ping as normal with Zzoomm.
Well, after what appears to have been a cable theft - a grand total of 10 OR vans were out the same night it happened, police helicopter etc - my CF connection was restored after 48hrs. Slightly confused that Zen don't think an outage affecting literally hundreds of households in an area is worthy of an outage ticket, but at least it works, and my 5G failover has now seen some action.
I bet they get you to plug in their supplied router to troubleshoot. :cry:
One of my early jobs was dealing with faults for a cable provider, so I appreciate the limitations of a call script/process driven workflow and sympathise. That said, one part of the conversation went as follows:
‘I can’t connect to your router’
No, I would imagine not, but as we just covered the red alarm light is on the ONT, and the most likely reason for that is no light on the fiber, and you never sent me a Fritzbox, I would be kind of worried if you could.
