- 4 Feb 2011
When you buy a gpu from them do they come with any sort of warranty?
No but a 30 day return window
Im really tempted with £4500 if I'm honest. I don't actually need the cash but for how much I use the pc I wouldn't be too far from making my money back on the whole pc....Well supply is thin, no signs of improving so things likely to get worse.
I'd only change my tone if you happened to be desperate for the money, in which case £3500-4000 today is a good option, but if its more a case of I don't need the money and I enjoy my 5090 then the only way I am parting with it is at £5000 plus and if it never happens I won't be regretting not take 3-4k.
Warranty.Why would you want a 5090 over a 4090?
I have a 4090, and particularly with recent mods that give you DLSS 5 and FG up to 6x should you wish, the extra few FPS a 5090 gives you just don't matter.
Not to mention a higher risk of spontaneously combusting.
at all the 'I don't need the money, but...' posts.![]()
GALAX launches world's first RTX 5080 with dual 12V-2x6 connectors, costs $3000 - VideoCardz.com
The GALAX RTX 5080 HOF Extreme arrives in China for 19,999 yuan, approximately $2,995. It features dual power connector locations, 13 Swarovski crystals and a 2805 MHz boost clock.videocardz.com
.I’m getting a bit nervous gaming now as it looks like an rma for a melted connector isn’t going to result in a new 5090 or anywhere near current value refund.
What’s safer, a power limit or undervolt? I’m currently undervolted to 0.89v
I know the power connector is the problem and it's failure causes the card to fail. Do you/we know if the failed and or melted power connector actually destroys the card in a percentage of cases or if the card usually OK behind the melted power connector?Haha , I would like a bit more overhead... we know these Intel processors like a little bit of power and Nova lake looks to be no different ( worse for the 52 core )
Yeah i think 95% would get away with a replacement plug , the only card that would actually be an issue getting a replacement for is the 5090FE as it uses a unique angled version of the 12V-2X6 connector and has a totally different connection on the board .. not available for sale anywhere afaik . With the similar performance thing i expect what is meant by that is say you send in an Astral but he wasn't able to replace that exact model so would get a cheaper version of a 5090, I doubt he would offer a 5080 as not exactly close in performance or price.
Yeah in an ideal world the wirepro itself would melt and just need replacing but with the way its designed and all its built in features would have to be pretty damn stupid to get it to that point, I've set mine to hard lock the system if an issue is ever discovered and works perfectly as intended, absolute piece of mind for this terrible design.
Going by my 4090FE that melted it was just the plug that got damaged... i can't remember the exact timeline but think it was around 6 months into my ownership ( from release date ) that mine melted, plug replaced and used it solidly for a whole year after that and put in some of the highest legit benchmark scores for a 4090 and countless hours on games and it didn't miss a beat .I know the power connector is the problem and it's failure causes the card to fail. Do you/we know if the failed and or melted power connector actually destroys the card in a percentage of cases or if the card usually OK behind the melted power connector?
We won't, I recon - not from the big publishers. They instead fire people, kill brands and move to pure money milking games like FIFA and the likes only. Everything else just not worth for them anymore - too expensive to make and investors moved to AI instead. A renesans of indie games but those rarely need fast GPUs.if there is a silver lining on these prices, as mentioned above I think (hope) we will see more efficiently made games to make hardware last longer.
Often? No so much anymore, when consoles are pretty much just PCs in a different box. Switch (2 as well) has always had some really well optimised 1st party titles but 3rd party ports were often really bad.often consoles , running almost potato hardware can run games at a far higher level than pc equivalents....
Not really, plenty of tests done with it, never revealed anything substantial. Same with Linux gaming.and imo the added background software a pc runs only accounts for part of that difference
That's what one can achieve studying static hardware for decades and using modern algorithms and methods that simply didn't exist back then. Sadly, pc gaming by big publishers is the opposite of that - ditch fancy optimisations and go for quick solutions then waste millions and redoing the game 3 times etc. Indie have quite a few examples where things were done very well but those aren't AAA so most people here don't seem to care.also going back further I look at some of the games and ports made on retro hardware now like the speccy, Amiga, mega drive etc and IF they had come out back when the hardware was relevant they would have blown people's minds and been a world wide phenomenon.
Yes the Thermal Grizzly one works perfectly and if you want to add more protection then also grab a per pin monitoring PSU of which the only one thats available at this minute and springs to mind is the MSI 1300w with their Safeguard plus technology which will monitor it PSU side ... Seasonic are also releasing their own version ( Optiguard 2.0 ) but still waiting for them to be released, Corsair are also releasing a new AX1600i Shift which will have same feature but gone very stingy on the outputs so wouldn't bother with that .So what's the consensus on these GPU power connection protector cables/devices made by Thermal Grizzly, Corsair, etc.? Do they actually work?
If you don't plug the connectors in properly, it will definitely melt. That much juice through a poor contact is going to be an inevitable disaster.So what's the consensus on these GPU power connection protector cables/devices made by Thermal Grizzly, Corsair, etc.? Do they actually work?
The TG unit can be set to whatever parameters you want essentially, you could make it set an alarm or shut off with just a 0.1 amp imbalance ( way too strict 2.0 amp is more realistic ) across the pins or shut down if it gets to 601w etc .. its almost fool proof if you leave all the safety features as standard and i would struggle to see how a cable would melt with one fitted without it throwing some kind of warning.
My brother used GPU Workshop and actually got paid £4400, even though when I checked they were quoting £4k.I have been offered 4300 pounds for my 5090 even if it was 5 grand im worried about sending it through the post to one of them GPU buying companies i have told my mates about it and they all say its seems too good to be true and sounds like a scam.
Yeh in reality he’s laughing and saying haha another one fell for it and sold.Dude is smoking something saying no profit in it for him
Tested the PSU yesterday, it also monitors the difference in amps between pins. You can set your own threshold for max amps and max difference.
Mines set to alarm, cut power limit to 70% and then can add shutdown too but not bothered with that.
Nice to have an extra 300w as well for whatever the next best GPU may bring us.
Best bit was no additional software, did it all through afterburner.
Also lmao at using a thermal camera, yeah let’s not bother with fit and forget, let’s pick up a little device now and then and inspect a connector. Great timesaver that.
Yeah I think it's more about they don't needs say anything at all about no profit for him. Just a thank you for your business type message and leave it at that.I mean he’s not going to reply like:
“Yeeeah bro, we’re getting them mad stacks on these, can’t believe people giving them away for so little lmao”
Never trust a salesman, ever.
