RTX 5090 End of Life, new 24GB RTX 5080 coming
Well supply is thin, no signs of improving so things likely to get worse.
I'd only change my tone if you happened to be desperate for the money, in which case £3500-4000 today is a good option, but if its more a case of I don't need the money and I enjoy my 5090 then the only way I am parting with it is at £5000 plus and if it never happens I won't be regretting not take 3-4k.
Im really tempted with £4500 if I'm honest. I don't actually need the cash but for how much I use the pc I wouldn't be too far from making my money back on the whole pc....
Why would you want a 5090 over a 4090?
I have a 4090, and particularly with recent mods that give you DLSS 5 and FG up to 6x should you wish, the extra few FPS a 5090 gives you just don't matter.
Not to mention a higher risk of spontaneously combusting.
Warranty.
:cry: at all the 'I don't need the money, but...' posts.
"the official announcement clarifies that the connectors are alternatives, not two inputs intended for simultaneous use."
If it was two to use together to spread the load like the multiple pcie 8 pins, then fair enough. An alternative is just giving you a spare for when one melts :p.
I’m getting a bit nervous gaming now as it looks like an rma for a melted connector isn’t going to result in a new 5090 or anywhere near current value refund.
What’s safer, a power limit or undervolt? I’m currently undervolted to 0.89v
Haha , I would like a bit more overhead... we know these Intel processors like a little bit of power and Nova lake looks to be no different ( worse for the 52 core ) :cry:
Yeah i think 95% would get away with a replacement plug , the only card that would actually be an issue getting a replacement for is the 5090FE as it uses a unique angled version of the 12V-2X6 connector and has a totally different connection on the board .. not available for sale anywhere afaik . With the similar performance thing i expect what is meant by that is say you send in an Astral but he wasn't able to replace that exact model so would get a cheaper version of a 5090, I doubt he would offer a 5080 as not exactly close in performance or price.
Yeah in an ideal world the wirepro itself would melt and just need replacing but with the way its designed and all its built in features would have to be pretty damn stupid to get it to that point, I've set mine to hard lock the system if an issue is ever discovered and works perfectly as intended, absolute piece of mind for this terrible design.
I know the power connector is the problem and it's failure causes the card to fail. Do you/we know if the failed and or melted power connector actually destroys the card in a percentage of cases or if the card usually OK behind the melted power connector?
Going by my 4090FE that melted it was just the plug that got damaged... i can't remember the exact timeline but think it was around 6 months into my ownership ( from release date ) that mine melted, plug replaced and used it solidly for a whole year after that and put in some of the highest legit benchmark scores for a 4090 and countless hours on games and it didn't miss a beat .
You can have a good look at the melted connection here: https://forums.overclockers.co.uk/t...w-24gb-rtx-5080-coming.19016184/post-38537813 as you can see no damage to the PCB at all ( its extremely thick anyway ) but damage is concentrated inside the actual plug socket itself.
if there is a silver lining on these prices, as mentioned above I think (hope) we will see more efficiently made games to make hardware last longer.
We won't, I recon - not from the big publishers. They instead fire people, kill brands and move to pure money milking games like FIFA and the likes only. Everything else just not worth for them anymore - too expensive to make and investors moved to AI instead. A renesans of indie games but those rarely need fast GPUs.
often consoles , running almost potato hardware can run games at a far higher level than pc equivalents....
Often? No so much anymore, when consoles are pretty much just PCs in a different box. Switch (2 as well) has always had some really well optimised 1st party titles but 3rd party ports were often really bad.
and imo the added background software a pc runs only accounts for part of that difference
Not really, plenty of tests done with it, never revealed anything substantial. Same with Linux gaming.
also going back further I look at some of the games and ports made on retro hardware now like the speccy, Amiga, mega drive etc and IF they had come out back when the hardware was relevant they would have blown people's minds and been a world wide phenomenon.
That's what one can achieve studying static hardware for decades and using modern algorithms and methods that simply didn't exist back then. Sadly, pc gaming by big publishers is the opposite of that - ditch fancy optimisations and go for quick solutions then waste millions and redoing the game 3 times etc. Indie have quite a few examples where things were done very well but those aren't AAA so most people here don't seem to care.
So what's the consensus on these GPU power connection protector cables/devices made by Thermal Grizzly, Corsair, etc.? Do they actually work?
Yes the Thermal Grizzly one works perfectly and if you want to add more protection then also grab a per pin monitoring PSU of which the only one thats available at this minute and springs to mind is the MSI 1300w with their Safeguard plus technology which will monitor it PSU side ... Seasonic are also releasing their own version ( Optiguard 2.0 ) but still waiting for them to be released, Corsair are also releasing a new AX1600i Shift which will have same feature but gone very stingy on the outputs so wouldn't bother with that .
The TG unit can be set to whatever parameters you want essentially, you could make it set an alarm or shut off with just a 0.1 amp imbalance ( way too strict 2.0 amp is more realistic ) across the pins or shut down if it gets to 601w etc .. its almost fool proof if you leave all the safety features as standard and i would struggle to see how a cable would melt with one fitted without it throwing some kind of warning.
If you don't plug the connectors in properly, it will definitely melt. That much juice through a poor contact is going to be an inevitable disaster.
As for the devices themselves, also depends. The first TG device didn't have per pin monitoring. Seemed pointless.
The second version does and this may help prevent a meltdown. It won't stop a defective cable or pin causing the contacts/connector to thermal overload, however unless the temp thresholds are reached. Then there is the added room for error by having two extra sets of pins and contacts required for the power connection. PSU manufacturers have also started creating their own solutions to tackle it in different ways.
The best thing you can do is inspect the pins before install and ensure the connectors are seated flush and plumb on both the PSU and GPU.
If anything doesn't look right, don't use it. I check mine with a thermal camera now and again and nothing unusual so far.
Oh, and before the AKSCHEWALLY people show up to feel better about their purchase: I don't think I could care less. Do whatever you want with your money and time. I'm not going to argue with you.
Tested the PSU yesterday, it also monitors the difference in amps between pins. You can set your own threshold for max amps and max difference.
Mines set to alarm, cut power limit to 70% and then can add shutdown too but not bothered with that.
Nice to have an extra 300w as well for whatever the next best GPU may bring us.
Best bit was no additional software, did it all through afterburner.
Also lmao at using a thermal camera, yeah let’s not bother with fit and forget, let’s pick up a little device now and then and inspect a connector. Great timesaver that.
I have been offered 4300 pounds for my 5090 even if it was 5 grand im worried about sending it through the post to one of them GPU buying companies i have told my mates about it and they all say its seems too good to be true and sounds like a scam.
My brother used GPU Workshop and actually got paid £4400, even though when I checked they were quoting £4k.
It was collected by DHL and the money was in his account the same day it was delivered to GPU Workshop.
He had this email from the guy that founded the company.
You got a great price, really, profit almost nil for us as there has been a lot of turbulence out there but we always honour our offers and I really wanted to show you that yhere are good guys out there in this crazy world with its Myanmar scam compounds! Now must get back to that screenplay! Take care Martyn, it’s been a pleasure and a learning process for us thank you.
I mean he’s not going to reply like:
“Yeeeah bro, we’re getting them mad stacks on these, can’t believe people giving them away for so little lmao”
Never trust a salesman, ever.
Yeah should work perfectly on the PSU side and I imagine have as tight a tolerance as you want , as long as you've got something to give you a warning be it PSU / WP2 or Astral then should be pretty damn safe going forward, spare headroom on a PSU never a bad thing as you say at this rate the 6080 will consume 600w as standard and 800w oc :cry:
I like the fact the MSI unit is integrated through Afterburner as I have that open all the time .
Yeah must remember to pull out the thermal camera while playing ( the point its most likely to melt ) Warzone and quickly check the cable to make sure one wire isn't getting too hot due to a current imbalance , my team mates will understand.... shame I didn't have a thermal camera to hand when my 4090 melted even though the plug was fully seated home , silly me:rolleyes::cry:
Yeah I think it's more about they don't needs say anything at all about no profit for him. Just a thank you for your business type message and leave it at that.
We all can see there is profit in for him by one look at ebay.
