General Headphone Audio
It's weird that no matter what I try, I end up going back to the HD 650. It is my forever headphone.
I'm down with the kids.....based.
Spent the evening on my HD 6XX. Love it.
With my ongoing DDR5 EXPO shenanigans I've bought a new temporary B850M mATX motherboard which doesn't include optical out. So it's messed up my very recent audio re-organisation using both optical & USB. So I really wanted to see if I could downsize my audio setup which resulting in spending hours tonight really comparing the K15 & K13 R2R. Honestly lucky to own either and they are both bloody brilliant, but I think since I've bought them I gained a slight appreciation of the K13 particularly driving the TA-66. I remember in a blind test I wasn't always able to tell them apart, so I don't know how much of this is bias, but it does feel like the K13 softens the source in a really nice way. Seems particularly apt with all the new K13's on the forum recently.
So I've ended-up with: USB -> K13 -> RCA to TA-66 & XLR to 4.4mm -> K15 -> XLR to Edifiers MR3. And then boxed up my iFi Zen CAN Signature 6XX. I still have the K15's dedicated controls which are nicer to use, whilst also leveraging the better amp. I can always easily add the USB lead back to the K15 if required.
I think what all this playing around has made me think about, is that when and if I change my audio gear, I'm wondering if it makes sense to have a standalone DAC + seperate AMP + OTL tube amp. 3 boxes instead of 2, but seperates gives a certain freedom. But the other thing I realised is that the K13 even on its own; its good enough. Like the HD 6XX sounds lovely on it. So I'm not sure how much I want to stray into more expensive DACs etc.
One downside is my GPU/TA-66 inteference is back. Even though the TA-66 is now really clean, a quick gaming session gave me a slight interference noise so need to resolve that one again.
Speaking of the Hd650, I'm still tweaking designs but I'm getting pretty damn close now to a HD650 with slamming bass.
I have a question for you all. Taken from this r/headphone post.
What is the 'A-B switcher' box at the bottom of this reddit poster's stack, below the silver K17?
I'm just curious as to what model/purpose it serves. Google image search was useless in this case.
@Timber I’m going to guess at either:
Input switcher to get over a single input limitation of the Fiio, so 2 inputs into the A/B and then on to the Fiio connection.
Or:
Output Switcher to A/B switch two connected sets of speakers (maybe in another room or a desktop set plus a music set).
Or:
Thank you. I did ask in the reddit post, but didn't get a response.
The K17 has USB, Optical, Coax inputs and can output Optical, RCA and XLR (apologies mis-understood what you mean by input limitation). The K17 could drive both the TA-20 and iBasso Kunlun.
Another one for those with headphones capable of rolling bass depths :eek:
But most especially this one:
I find it hard to comprehend how the 490 Pro is capable of this sort of bass with the 2nd track, it easily rivals the old Hifimans for bass depth.
Think I've fixed it.
I bought two things, although I think it's the cheap RCA Ground Loop Isolator that probably did it. In summary when gaming I cannot hear the GPU-induced interference, even ramping up the frame-rates. I did buy some ferrite cores where I fitted one to the USB cable from the PC to the K13 so that may have helped too. This has also got rid of small consistent 'squelches' (best way I can described this) that became more prevalent on the most recent move-around due to the new motherboard.
I've spent most of the evening on the TA-66 and it's now cleaner than it's even been. Not even heard the mobile phone signal interference either. So the cheap fix(es) appear to have worked and I've actually been using the DT 880 (600Ohms) properly for gaming which is cool.
The 490s look to be tuned with a good chunk more bass than hifiman's.
A shame really that with one set of pads they look to lack the warmth of the 650s mid bass hump and with the other they lack the mids
I would say the memory foam pads improve upon the stock velour pads as well for both low and mid bass, I boxed the stock pads a while ago though so haven't tried the above tracks with those as the memory foam pads Seem to cover everything I like and remind me of the feel of the voarmaks pads on the hifimans I had.
My assumption without having time to look, is that the other pads included with the 490 Pro flatten the bass and provide a more neutral response (i.e. slightly flatten the bass).
I know FR isn't everything, but when you look at the 505/550 vs. the 650/6XX by god did Sennyheiser (Sonova) nail it. That said I didn't like the comfort of the last 5xx (560S) so I'd never wear them. And that's one area the 490 wins (I suspect).
Also side-note Aune AR3000 gets close to the 490 there, just very different treble.
Also side-note Aune AR3000 gets is close the the 490 there, just very different treble.
Yea the other pads seem to flatten it out and bring it closer to the hd600 though not quite the same.
Finally got somewhere with my damaged K13 amp returns being processed by Advanced. They've offered me a refund or a replacement stating "We have new sealed stock of this model so we can replace it for you as the clearance unit you bought should not have been sent out without proper packaging."
So I just asked for the replacement. I don't know if sealed stock means a proper new boxed amp or what however but I am not fussed. I just want to get it setup so I can move onto getting myself a CD transport and also sorting out my HD600's knackered cables!
Edit: Just received an update from Advanced. Looks like they're sending out a brand new boxed K13 as the invoice shows a cost of -£279.99 on it!
Get the HD600 cable from Ali (currently there are sale codes) and get yourself that black ET3 if it's still there! End game CD transport :p
Hmm that's a top loader mate - probably overkill for me too! See I wanted something to sit in between my MacMini and the K13 so I'll be looking for a machine with a similar footprint and it being a slot or tray mechanism.
I had been sold on the Shanling CR60 or CD80 since you mentioned it ages back but I see there's a new CD50 too. They're within my price bracket of <£300 too!
Looking at Ali for cables now, cheers!
Top Loader > Tray. for less moving parts.
One thing I haven't mentioned, and I don't think many reviews mention, is how quiet the ET3 is. It loads fast and when it is spinning, i can't even tell. I would record the noise, if there is any to record. It's like as quiet as the fan inside the new Mac Mini.
But it does mean you need like a foot of clear space above it to use it, like having a record player.
The CD50 looks decent, the Fiio DP11 as well. Lots of choices!
BTW you can get the Fiio for under £140 at the moment, another £8 off using Paypal it seems. It will be under the £135 threshold limit then! But being so close to the limit it is usually fine.
Half the price of the CD50, tempting huh?
