Fan curves
25 Sep 2019
Not sure if this is the right place but it's cooling question.
A friend helped me set up some fan curves using fan controller (as my fans were going wild all the time and revving etc) and it fixed the problem but now I seen should really do them in the bios rather than a 3rd party app in windows but is there a way to transfer the information or is it going to be a case of manually doing it in the bios as that I have go stuck on before hense using fan controller but I read bios is much better and obviously windows is using less stuff on start up etc.
Manually do it in BIOS, but if you know the values then jot them down on paper and note what fan goes to where on the Mobo and what temp reading that fan is responding to ( usually CPU but not always )
You can also set up an alarm if a fan stops working, at least on some mobos you can.
I always set up alarms whenever possible.
You can not transfer as far as I know.
I think you’d have to set your fans up manually in BIOS.
Fan control is a brilliant bit of software though and is my preference now, it's so customisable.
I had an issue with a new case, a phanteks with 140mm fans ans at certain RPMs there was some resonance through the case at certain RPM's, so I basically made the fans ramp up (for example i cant remember the exact figures) immediately from 30% speed to 50% speed as I was getting annoying resonance between 35% speed and 45% speed.
It's far superior to doing it in the bios, IMO, I've always found BIOS fan control a bit clunky.
Ah yeah I thought that would be the case and sounds like I'd **** it up lol.
Oh ok I had difference of opinions so far which seems to be the case with tech some preferring one way over another don't use third party tools it's better in bios some then other way but I suppose if fan control is doing it's job not causing issues why change lol
bios doesnt know the temp of your gpu where as the windows app likely does and the fans on the case probably ramp up with the temp of the gpu not the cpu.
depending on what cpu you have the cpu can only be like 50c and the gpu is pimping 70c heat into the case, it kind be a negative to have fan profiles in the bios set to what the cpu is doiong.
your motherboards bios only knows the gpy temp if the motherboard has a temp sensor on a wire you can position yourself and I don;t think any motherboard comes with that and most likely won't even have it as an option.
I think its a 3rd party hardware fan controller thing.
Will stick to fan controller then
It's a case of: there is no truly right or wrong answers and basically, you do you.
Some will prefer bios control (like me) and others will prefer using windows apps.
Pick whichever floats your boat.
Struggling with this myself. I replaced the fans on the AIO of my NR200 Max v2 as one of them was rattling like a cable was touching it (bearing). Replaced them with a couple of Noctuas but it seems louder now. Done a fan curve in BIOS (ASROCk Fan-tastic) but doesn't seem right. Getting a lot of random ramping up and down at idle. Not sure whether to limit the max rpm even more or restrict the power going into it.
Look for a hysteresis setting. It should allow you to set a number of degrees centigrade over a number of seconds before it changes speed. This will stop the fans spiking up and down, but still allow them to spin all the way up or down based on the overall temperature.
Thanks. My motherboard is a budget 650 ASROCK so seems to be missing some of the fancier features. Not helped by a hilarious lack of instructions in the manual.
Just use fan control and have it start with windows so once you've set it up to your liking you never have to touch it again.
You can do so much with it. I'd suggest watching a few YouTube guides though as it's not that obvious how to do various things like identifying and naming fans, and doing mixed curves etc.
For example it sees my gpu as one fan (it's a 3 fan gpu) due to how my gpu fans are wired, some gpu's will present 3 fans individually so you'd more than likely want to set all 3 fans from one curve profile in that scenario, etc.
Yes mattyfez is right, FanControl is always the answer. I think there is some kind of setup wizard that now helps you do the initial setup, so it does guide you through. It's really not that difficult once you understand:
1. Have it id your fans.
2. Have it id your sensors.
3. Chose a fan curve and link it to the sensors you want to use.
4. Tell the fans what curves to use.
So it works Sensors -> Curves -> Fans
Once it's all linked together it's easy to tweak and change things to how you want it to be. There are multiple curves types you can tweak, multiple sensors you can use and you can even decide to have individual ones for each fan or just have them all running together.
You might need to change the BIOS fan settings to be "manual" so that the BIOS doesn't fight with Fancontrol, and it's often handy to set Fancontrol to run as a service so it's always working even if you are not logged in.
It's a great tool I aggree
