Based on what?
Based on it being far more clunky and annoying.
Why should I need to look away from the road to turn the heating/AC up.
Looks like NCAP agrees...
Based on what?
I get what you're saying but even if it's always in the same place on a touchscreen you've got no physical landmark to guide you to it so you generally will always have to at least glance at the screen. A physical button/knob, hand out give it a twiddle (fnar) eyes never leave the road.I really don't get that argument.
The heating controls are in the same place 100% of the time. What difference does it make if it's a physical button or a button on a GUI as long as it remains in the same place.
How do you see the temperature you set without looking at the little LCD next to the physical dial?I get what you're saying but even if it's always in the same place on a touchscreen you've got no physical landmark to guide you to it so you generally will always have to at least glance at the screen. A physical button/knob, hand out give it a twiddle (fnar) eyes never leave the road.
Not sure I agree.That is a genuinely baffling choice by Tesla. Though the glovebox is so small you can't really put much in there anyway. I just have a microfibre cloth and that's about it.
Not sure I agree.
It having an electronic release means you can lock the glove box with something which isn’t tied to a physical key (not that the car has one). It also automatically locks when in valet mode etc.
It’s not unique to Tesla anyway, the Polestar 4 I drove the other day was identical. The lack of a physical key isn’t unique either, sure some cars have emergency key blades but no one is getting that out to lock their glovebox.
NCAP permits climate control temperature adjustment to be via touch interface as long as it's sufficiently large and segregated.Based on it being far more clunky and annoying.
I just think it's a bit weird locking it behind software instead of a much simpler solution of a hatch. But as you say it makes securing it a hell of a lot easier.
That's the point though isn't it? The current temperature is irrelevant, want it half a degree warmer = one click to the right. A degree cooler = two clicks to the left etc.How do you see the temperature you set without looking at the little LCD next to the physical dial?
Not sure how you're odd for doing that.I'm probably the odd one but if often fiddle my temperature up and down between 20'C and 22'C based on how I'm feeling and what I'm wearing.
Now you are just making stuff up.A bit annoying having to switch the car on and press buttons just to open it. Even more annoying if you have disconnected the battery and then need something from it.
It's the same on the haptic screen, one click is 0.5c.That's the point though isn't it? The current temperature is irrelevant, want it half a degree warmer = one click to the right. A degree cooler = two clicks to the left etc.
I set mine to 28 and work it down over the course of a 47 miles drive. Although it's not unusual for me to forget and it still be blasting hot air at 28 when I get there!![]()
