QLC and TLC NAND
25 Sep 2019
I'm looking at getting a new storage drive to replace my current 1TB drive with a 2TB one. At the moment I have a Lexar NM790, which uses TLC NAND, but I've been looking at the Kioxia Exceria G3 2TB PCIe 5.0 drive, which uses QLC NAND.
The drive will be used purely for game storage, as I have a separate drive dedicated to Windows.
My question is, how much of a downgrade is going from TLC to QLC NAND in real-world use? Does TLC make much difference when it comes to game loading times and gaming performance, or is QLC perfectly fine for a dedicated game drive? Would I actually notice any difference between the two, or would you stick with TLC?
I have never used a drive with QLC nand, but have noticed the Kioxia drive you mentioned get recommended a lot on here.
I have read that they (QLC PCI-E 4 drives) are ok for game drives though as they are not continually written to so it may slow down when actually installing a game.
Am sure someone with more knowledge will be along soon to give better info.
Yeah I did read that about the installing games but I could live with that as long as the performance isn't much of a diff a
Higher-end (or newer) QLC drives are not noticeable in real world usage, except for when you saturate the cache (like doing huge file writes/transfers).
I have a 4TB Samsung 870 QVO SSD that I wanted to use as a backup. Turns out QVO SSD's are terrible for long writes. It has a small SLC cache which once filled drops writes down to 160MB/s.
So for my game drive a QLC would be perfectly fine only read and write would be the Installation
A good QLC drive, yes.
The worry with QLC previously, is that they would pair poor QLC, with low-end DRAMless controllers. That was especially bad in low capacities, though most reputable manufacturers used TLC for 500GB or less, even on cheap drives.
I was looking at the kioxiaria Experia 2tb G3 it's QLC is that a good QLC drive
QLC drives are only bad for long sequential writes or if the drive is very full. For most users neither is true so for most users it'll be fine, espesh if it's a 2TB drive.
I've had a Samsung QVO drive for a long time now, I wouldn't use it as a system drive, it's mostly for installing games onto.
Its fine :km:
