**THE NVIDIA DRIVERS THREAD**
Not just me confirming this now!
WCCFtech coverage now too.
I am back on the Studio driver btw, just did the pwoershell command to stop nvtopps entirely and the logfile erased itself and has stayed that way after long session and idle testing.
Probably wise to run it anyway even if so far you are not affected, keeps the telemetry stuff from running even if randomly.
What command and log file is this skipper ?
The logfile that nvidiadisplaycontainer writes to:
C:\ProgramData\NVIDIA Corporation\nvtopps\nct
Mine was 19MB, and because of the write loop, the nvtopps service overwrites the whole file repeatedly instead of appending to it hence the runaway disk writes.
The powershell command is:
Code:
New-Item 'HKLM:\SYSTEM\CurrentControlSet\Services\NVDisplay.ContainerLocalSystem\Parameters\LocalSystem\_nvtopps' -Force | New-ItemProperty -Name DisableLoad -PropertyType DWord -Value 1 -Force
Then
Code:
Restart-Service NVDisplay.ContainerLocalSystem
This stops the nvtopps service from loading, and removes the logfile.
You can check the folder from time to time if you ever suspect the service has started again such as after a new driver install, then rerun the PS command to fix it again. There is every chance the issue exists on 621.01 as well but the conditions to trigger it just have not been met yet, seems the only 100% way to stop it is the PS command.
Code:
Then
Code:
Hmmm I will do this thanks. I did check via resource monitor on the disk tab and didn't see nv container so I just assumed I would be in the clear, suppose won't hurt to do this command though
  • Like
Reactions: mrk
So an nvidia dev reached out to me to test a beta driver to see if the same observations are made, currently testing....
