I've got a E6700 running at stock on an Abit IP-35 PRO in an Eclipse 62 (Drive bays removed and cables tidied for best airflow). Heatsink is a Noctua U12F with 2 noctua fans strapped to it in push/pull config.
Heatsink has been mounted (correctly!) with the correct amount of AS5 (I've remounted it a number of times).
Neither Heatsink or CPU appear to be convex/concave - yet temps are about 49degrees idle 60degrees load (coretemp). I'm fairly sure they shouldn't be that high, heatsink isn't hot to touch so I'm fairly clueless
Tempted to give in and just buy a TR 120 Ultra and a G0 Q6600 but I'd like to get to the bottom of this first
Any help would be appreciated!
