I'll be reinstalling Vista on mine when I get it, so thanks for this! Very helpfulI'd recommend a re-install of Vista... <snip>
Jon
Does this come as standard or do you have to add it. I really wanted one of these but i don't remember seeing one in the specs or options8. SD card reader
Does this come as standard or do you have to add it. I really wanted one of these but i don't remember seeing one in the specs or options![]()
Did you go for a 32-bit or a 64-bit install of Vista? I'd like to go 64-bit because of the more secure kernel but was wondering if there were a lack of drivers.
How come none of you are getting any additional warranty (i.e. you are choosing the base 12 months)? Is it your intention to flog the laptop after 12 months? I would have thought warranties would be more important on laptops as they aren't particularly user serviceable.
Right, my first major issue with this laptop.
If I set the screen brightness anything lower than max setting, a buzzing/high pitch whine can clearly be heard. Its damn annoying as I find it too bright on max setting. Have to put it around 2-3 notches below.
I'm going away tomorrow for 2 days but when I get back I'll have no option but to send it back for a replacement.
Gutted as the screen is perfect (no grainyness issues as reported by some people) and my headphone jack is fine. Got the laptop hooked up to my stereo amp, listening to MP3's all evening and zero problems.
Can you not just adjust the gamma/brightness in the control panel to fix that GJS?
GJS its a well know problem with the dells,
also along with the cpu noise through the headphone socket.
I get the noise on my acer, when watching a dvd on the tv and using the headphone socket into the tv, its quite bad.
Havent heard the screen whine though.
Some issues are due to the T7300 series cpus ie headphone noise. Which the dells are supposed to suffer quite bad.
Screen whine is dependant on what panel you get i believe. Check out the notebookreview forums. You will find a fair few people suffer from that as well
Is your screen grainy? thats one thing i was worried about and the lead times.
may i ask how noisy these are please
im after a high spec silentish lappy.
Do you think there would be somehow i could order one with dell with a more custom spec ?
i want a truebrite screen, the 1.8ghz c2d, 4gb of ram, but i dont need a geforce card, onboard will do, i have a rig for gaming, only use lappy for photoshop, dreamweaver, etc...
The panel on my Vostro is from Philips and there is no graining at all. It's the AUO displays that seem to be having the problem.
