[TW]Fox;9987281 said:Believe it or not its actually the M5 that only has a manual box option in the USA.
Well a friend came past my GT3 in his 660bhp SL65 AMG at the weekend like it was parked. V12 with twin turbo's and 900lbs of torque, I hear it made the day 1 second longer because it slowed the earth down!![]()
I predict the RS6 will have a top speed of 195mph.
What leads you to this conclusion?
I would have thought higher. An m5 does around 205mph when delimited. I would say around the same as the audi will be abit heavier.
Both are hand built by one engineer, difference is that the 55 is 500bhp supercharged v8, 65 is a 600bhp twin turbo v12.I don't know why anyone would buy the SL65 AMG when it's about 50 grand more than the SL55 AMG. There isn't that much between them other than the engine and the fact the 65 is hand built (apparently).
Based on the rest of the A6 range, I'm guessing 208 mph too.Weight is largely irrelevant. It's a simple battle between power required to keep the car accelerating against the forces holding it back.
If the M5 can break 200mph with 520 ish BHP, i'd comfortably expect the higher powered Audi to be 8-10mph faster (unless prevented from doing so by lower gearing)
I suggest your perspective is somewhat different to the owners...I don't know why anyone would buy the SL65 AMG when it's about 50 grand more than the SL55 AMG. There isn't that much between them other than the engine and the fact the 65 is hand built (apparently).
I suggest your perspective is somewhat different to the owners...![]()
