Hi, after trying to upgrade this old 939 system ive decided to bite the bullet and go intel and c2d. This will be my first intel system
After hours of looking around ive put together this. Im hoping I can run this on my current Enermax 495W ATX2 psu (EG495AX-VE) if possible. I wont be overclocking. I also wonder will my current SATA hardrive run in this fine? is sata backwards compatible (Serial ATA-150, 7,200 RPM, 16MB - MPN: 6L250S0).
Intel Core 2 Duo E6550 "LGA775 Conroe" 2.33GHz (1333FSB) - £115.14
Asus P5K Intel P35 (Socket 775) PCI-Express DDR2 Motherboard - £88.11
GeIL 2GB (2x1GB) PC6400C4 - £64.61
768Mb 8800GTX PCI-E (x16) - £293
Akasa PCI Express 6-Pin to 4-Pin Power Adaptor - £3.51 (my psu only has 1)
I wasnt sure on the major difference between a E6550 and an E6600 apart from the £40 difference the different FSB and a tiny bit more performance.
Anyone have any other recommendations and will all this work together ok?
any help appreciated, thanks
Mike
Mike
