- 19 Jan 2003
- west sussex
The only thing i can think of is that being under phase for 2 months might well have had an effect on the epoxy intel use to put the ICH on the CPU's.
epoxy cracks when frozen and then when it went back to water cooling the expansion of the epoxy might have cracked a core or to. but i have never read anywhere that this had happened before so its only guess work!
The thing is the cpu was 100% solid untill the reset of death, which it had never done before. it just shut off instantly and restarted to another reset after a long boot and poor performance of no longer than 10 mins. then no more, just constantly restarting with no M/B beeps or beeps from the enermax galaxy 1000w which has its own diagnostics beep system for PSU problems.
The only thing i will say is if i turned off the power for 30 mins it would post to bios load screen and sit there frozen on the loading USB devices screen, then it would reset and keep reseting untill it was turned off.
This new GO chip runs cooler and has been 100% solid since instalation in the same board with same hardware.
Well iam going to make a key ring out of it, to most it will look like junk, but for me it will be the most expensive key ring i have ever owned, cant wait to see people reaction if they ask what it is ect and i say it cost £600. never know i might get some dimwit to buy it lol but i dout it!
<maddness> can i have the QX6700
please
Even had it overclocked slightly using a different timing crystal. Think i got 27Mhz out of it or something.
