Another consideration, those cards at full tilt will be working your sig psu very hard. Mentioned in another thread they can pull over 500w each under load.
Just a mention.
guru3d said:Measured power consumption
System in IDLE = 187W
System Wattage with GPU in FULL Stress = 447W
Difference (GPU load) = 260W
Add average IDLE wattage ~ 20W
Subjective obtained GPU power consumption = ~ 280 Watts
Running sli 580s on 850w is asking for problems tbh
Surely a single 580 would be more than enough to game on a 30" screen?
Stoner81.
There’s an easy solution to this, buy a 1920*1200 monitor.
2560x1600 is too much, buying a monitor with this resolution is usually the start of a very expensive and unnecessary upgrade path.
By the sounds of things he already has one 30" monitor. Personally I love the extra resolution on a 30" monitor, upgrades needed or not.
Which is why I said buy a 1920*1200 montor, if all you do is game higher resolutions are pointless.
My advice is gid rid of it now unless he actually needs it, which I doubt.
