You'll go even quicker and make a lovely noise cutting through the air. There's also the aesthetic consideration. Some love the look others not. Downside, crosswinds are much less fun...
Am I going to lose a lot on comfort though?
Am I losing/gaining much in comparison to the Ultegra on the Cube?
Not really. My 2007 Cervelo has an aero profile and it's no different to my 1989 skinny steel frame in a cross wind. The only thing that really has an impact in those conditions is the front wheel profile.
I'd assume nothing and get bike fit before you make an expensive mistake and buy something that potentially going to cause you an injury.What about this? http://www.bikesheduk.com/bikes/road-bikes/cube-agree-gtc-di2-slt-compact-2013
Assuming I'm a 56..
At the very least measure yourself and use this as a rough guide
http://www.competitivecyclist.com/Store/catalog/fitCalculatorBike.jsp
Last thing you want is a £1,500 bike that gives you something like sciatica
Assume was probably the wrong word... I just meant if I am a 56 then I'll be able to buy that, but I'd have to check that first.
and don't presume any bike shop is going to size you up and order the perfect bike because in my experience it's not going to happen
Going of my last purchase I would have ended up with a bike too big if I had listened to the shop worker who was mildly amused someone almost 6ft6 was ordering a 58cm frame cx bike as "I ride a 58cm and I'm a midget compared to you"
Most shops still use the archaic stand over height as a guide
Ask around, there will be LBS' around you with a better rep than others.
Also £1500+ is a lot to spend on a bike without telling us what you're using it for! If you're commuting I would say mudguards are a MUST and discs would be ideal if you are riding in all weathers.
If you're looking for a first bike to ride out with friends and get some miles in then the more related geometry of the Defy range would suit you well (I ride a Defy 1 2015 for pleasure & commuting). If you already ride MTB and want something 'faster' then you're probably best looking at a CX frame - similar geometry to the Defy style bikes. If you're after a weekend bike for flat out speed and have fast friends then the TCR/Reacto/Cube/CAAD10 all fit that profile.
Are you needing any kit (helmet/pedals etc) then you can also get them as part of the C2W but of course they'd eat into your 'budget'...
Most of the time I go for a couple of hours 30-40 miles with the occasional weekend 60 miles. No racing planned as yet, although I do have a great tendency to try go as fast as possible...
I answered that earlier.
I'm not looking to go out in all conditions. 'If you're after a weekend bike for flat out speed and have fast friends then the TCR/Reacto/Cube/CAAD10 all fit that profile.' is probably closest out of your options for me
No kit required really, I have most of it apart from the bike!
I'm in West London near Twickenham if anyone has any suggestions for good LBS? Don't mind travelling into London either..
Ribble quality is good but their service is terrible.
A number of folk here have and love their frames.
http://www.sigmasport.co.uk/
Quite close to you
Just seen on SportPursuit they have Guru bike fit at Cycle Surgery Lee Valley Velopark Store in the Olympic Park, East London for £99.
Would that be worth doing before I get a bike? The price is more affordable!
http://www.sportpursuit.com/blog/guru-worlds-most-advanced-bike-fit-system#.VVy0D1VVhBc
