- 5 Jul 2007
- London
The 1.4 XSi box is as follows:
(Gear) (Ratio) (MPH)
1st = 3.41 - 32
2nd = 1.95 - 55
3rd = 1.35 - 86
4th = 1.05 - 103
5th = 0.85 - 127
With a Final Drive of 4.29
1600 XSi/S2 Rallye Box.
1st = 3.41 - 33
2nd = 1.95 - 59
3rd = 1.35 - 91
4th = 1.05 - 109
5th = 0.85 - 134
1600 XSi/S2 Rallye box (Which i may consider depends on which i can get, has the same ratio's as the 1.4 box but with a final drive of 4.06) would ideally like to keep my ratios the same though.
The GTI/VTS box is as follows. (Would work out as those speeds on my current wheels and tyres)
1st = 3.471 - 34
2nd = 1.95 - 60
3rd = 1.36 - 87
4th = 1.05 - 112
5th = 0.85 - 138
With a Final drive of 3.938
Doesn't seem like a massive difference in speeds, it will cut the acceleration though, and its putting more strain on the clutch, its only a 1.4 and needs all the help it can get really, so the shorter the better imo.
Hope that makes sense.
Tom.
Edit just corected it for my exact tyre size and rev limit.
1st = 3.41 - 32
2nd = 1.95 - 55
3rd = 1.35 - 86
4th = 1.05 - 103
5th = 0.85 - 127
1st = 3.41 - 33
2nd = 1.95 - 59
3rd = 1.35 - 91
4th = 1.05 - 109
5th = 0.85 - 134
1st = 3.471 - 34
2nd = 1.95 - 60
3rd = 1.36 - 87
4th = 1.05 - 112
5th = 0.85 - 138
Tom.
was looking forward to getting back on the road.
