£1100 gaming pc build
2 Jun 2005
Hi All,
I am thinking of buying these parts, all opinions welcome: -
Case CORSAIR SPEC-03 COMPACT GAMING CASE - RED LED
Overclocked CPU Overclocked Intel® Core™i5-6600K Quad Core (3.50GHz @ upto 4.60GHz)
Motherboard ASUS® Z170-P: ATX, LG1151, USB 3.0, SATA 6GBs
Memory (RAM) 16GB HyperX FURY DDR4 2666MHz (2 x 8GB Kit)
Graphics Card 4GB NVIDIA GEFORCE GTX 970 - DVI, HDMI, 2 x mDP - 3D Vision Ready
1st HD 250GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2nd HD 3TB WD BLACK WD3003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
DVD Drive 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
PSU CORSAIR 650W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Cooling Noctua NH-D15S Ultra Quiet Performance CPU Cooler
Thermal Paste ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
OS Windows 10 Home 64 Bit - inc DVD & Licence
Do you really need an optical drive? Consider an external USB one instead.
Do you need a monitor? If not, what is the resolution of your current monitor?
Consider getting a bigger SSD and ditching the HDD entirely.
The Corsair CS series PSUs are manufactured by China Great Wall Computer Group Co. Ltd. You should go for a quality device from Seasonic or similar, and you only need a 450W PSU unless you're going to put a second GPU in.
Do you really need an ATX system? Might an ITX system be more suitable?
But it will be wholly legitimate. Unlike a lot of key resellers, who sell the same key to multiple people or sell pirated keys. They'll be cheap for a reason
