increasing voltage of the ram might cause global warming and economic collapse
Aawww poo didnt think of that LOL.
Well go ahead and get faster ram and take advantage of 2-3% increase (if that) in FPS in games! woohooo!
"timings mean sod all with ram" hm gotta disagree !
I have seen better benchmark scores from my own system using lower clock with tighter timings than higher clock with slack timings
I would be very surprised if it made even 1fps difference in any game.. I don't doubt its faster in benchmarks but that doesn't translate to the real world with ram timings, I've bought tighter ram myself in the past and been completely disappointed with no performance increase at all (that was in any way perceivable by a human being that is.. it was there is a 0.025s faster time in Super pi or something)
from what i hear a q6600 should reach 3ghz quite happily i believe some members here have them running at nearly 4ghz, if you're really that worried about temps, try re-seating it as it may drop the temps a bit if that fails and you want a new cooler you got a few choices in the form of the TRUE/sunbeam/noctua & titan
2gb of ram? u want me to go down in ram?
also im on a zalman hs ..it did about 1/2 degrees difference over the stock cooler.. i was most put out.
Yup, I'm on 3.4 very easily with load temps of 65C. Only with an Arctic Cooling Freezer 7 Pro! And I'm new to clocking.
so, its a tough one for me as i know clocking the 6600 should be fairly nice but im on 2.5 odd at the mo and idle is 42 load is 52 ish so id rather get some more cooling before i push it any further.
The idea ive had so far is:
new heat sink+fan for cpu so it can hit 2.7/2.8 ish
hmm .. so.. intels are happy to go to that level?..
hmm odd...
