- 1 Dec 2015
got windows CD/USB to boot from and see if repair is needed ?
boot menu picks it up. when i click it to boot from it, it goes back to he same error almost like no OS is installed.
would it matter if i put the Sata cable the wrong slot
i have 2 ssd drives and 2 hdd drives.. only the OS drive is connected..
When you installed windows did you have all the drives connected to the motherboard or just the drive that you wanted to install windows on to?
If all the drives were connected during installation, windows randomly adds boot data to a different drive if this is then relocated / removed it will cause the error that you had and as you have swapped cases it seems likely.
i had, this, or currently do- moved boot drive to 500gb nvme when 250gb had it. though was caused by error with windows update
all drives where connected at the time of installing the OS. better just to do a reinstall and leave all drive out apart from the OS until the OS is installed.
Hmm just been looking at my specs and the - Ryzen 7 2700x i see this - Bundle Contains AMD Ryzen 2700X Eight Core Processor with 4.35GHz Boost after checking mine it only running at 3.70GHz its running more like a Ryzen 7 eight core 1700 3.70GHz
not sure if i need to enable something in bios or flick a switch for the boost.
i have also noticed that the Memory i have says Dark T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black/Grey but checking specs the memory is running at 2133 ish
is this just me or would i need to enable it.
stays at 3.70GHz we do proper checks when i get home from work and get more information.
the ram i didn't enable anything, is it worth enabling it.
snaps when i get home from work
will run cinebench also, i did try and change some setting in the bios.. but it was grayed out for me and it wouldn't let me click on it.
