£1500 build :)
Adding 2 gpu's and 2 monitors takes it over :(
YOUR BASKET
2 x MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £359.99 (£719.98)
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM £249.95
2 x Iiyama Prolite E2773HS-GB1 27" Widescreen LED 1MS Monitor - Black £209.99 (£419.98)
1 x Gigabyte Z87X-UD4H Intel Z87 (Socket 1150) DDR3 ATX Motherboard with *FREE COOLERMASTER SEIDON 120V COOLER £163.99
1 x Antec High Current Gamer 850W Modular '80 Plus Bronze' Power Supply (0-761345-06225-1) £125.99
1 x NZXT H440 Mid Tower Case - Black £94.99
1 x Avexir Core Red Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CIR) - Red Light £79.99
1 x Toshiba SSD HDTS212EZSTA 9.5mm 128GB Solid State Hard Drive - Retail £79.99
1 x Toshiba 2TB 7200RPM SATA 6GB/s 32MB Cache - OEM (DT01ACA200) HDD £59.99
2 x Zaward Golf III Fan 140mm LED ZG3-140F - black/red £10.98 (£21.96)
1 x NZXT CB-LED10-WT 12x White LED Sleeve - 1m £9.98
3 x Zaward Golf III Fan 120mm LED ZG3-120F - black/red £9.98 (£29.94)
1 x BitFenix Alchemy 24Pin ATX Extension 30cm - sleeved black/red/black £7.49
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Red £5.99 (£11.98)
2 x BitFenix Alchemy 6pin PCIe Extension 45cm - sleeved black/red/black £5.99 (£11.98)
2 x BitFenix Alchemy 8pin PCIe Extension 45cm - sleeved black/red/black £5.95 (£11.90)
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Red £4.99 (£9.98)
1 x BitFenix Alchemy 8Pin EPS12V Extension 45cm - sleeved black/red/black £4.99
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Red £4.49
4 x BitFenix Alchemy 2pin I/O extension 30cm - Red £3.95 (£15.80)
Total : £2,135.34 (includes shipping : FREE).
What happened to wanting a plain black case ? :D
I saw that NZXT haha! :p
Awesome guys, might try push the budget out a bit!
Wont be buying this till May time, just wanted to put the feelers out to start getting back into the loop :) Is there any major tech coming out between now and then which would change the spec?
And ill come to you Ethermaster when its time then eh? :p
ASUS have a 27", 1440p, 144hz, G-Sync monitor that should be with us by May - the perfect storm of monitor features. You'll need an Nvidia card to make use of G-Sync.
Any news on price yet?
And from reading Nvidia cards run cooler and quieter than AMD, which is something I think is important :)
Would a set up with 2 of those monitors and 2 Nvidia cards come in at under 2k?
But then I imagine it would ruin the red/black colour scheme?
I seem to remember Gibbo hinting at £550-600 for the price. Not cheap, so two of them? No. But then I don't see the point of getting two gaming monitors anyway. One or three - otherwise you'll just be staring at the bezel all day.
Lee's build above with two MSI 780 Gamings minus the monitors and unnecessary fans comes in at around £1500. And the colour scheme is maintained.
Hmmm so much choice, are 780's the nvidia card to get for this budget at the moment?
This has been great to get me up to date guys! Ill be reading over the next month and will come back once I have a final budget :)
Really would like a multi monitor set up, opinions on 1x27" vs 3x24"?
So maxing out the 2k budget with 3x24 or spending 1500ish with 1 27" with the view to grow to 3?
Yup, a couple of 780s makes sense at the budget.
Personally, I'd much rather have one 27" 1440p 144hz G-Sync monitor than three 24" 1080p ones. But if you really want more than one monitor, three 24" ones make sense. Three of those ASUS ones would get very expensive, and I'm not actually sure how two 780s would cope with three 1440p screens.
Fortunately, you've got a month or two to decide. That means you can wait for reviews of G-Sync monitors are available so you can make a more informed decision.
