- 12 Feb 2014
- Somewhere Only We Know
G.Skill do some nice kits, not cheap though, just google the part numbers, anything 3600mhz C18 is going to be the new Hynix CJR chips or there abouts.
128gb (4x32gb) 3600mhz F4-3600C18Q-128GTZN - not sure which IC's this kit uses.
64gb (4x16gb) 3600mhz F4-3600C16Q-64GTZN 16-16-16-36 - Samsung B-Die
Dont confuse with the blow
64gb (4x16gb) 3600mhz F4-3600C16Q-64GTZNC 16-19-19-39 E-Die
64gb (4x16gb) 3600mhz F4-3600C18Q-64GTZN 18-22-22-42 Hynix CJR
The same part numbers apply if you just want 2 x 16gb sticks, just change a couple of digits:
32gb (2x16gb) 3600mhz F4-3600C16D-32GTZN 16-16-16-36 - Samsung B-Die
32gb (2x16gb) 3600mhz F4-3600C16D-32GTZNC 16-19-19-39 E-Die
32gb (2x16gb) 3600mhz F4-3600C18D-32GTZN 18-22-22-42 Hynix CJR
To break the part numbers down:
F4 = DDR4
3600 = the ram speed
C16/C17/C18 = Cas latency
Q-64 = Quad channel matched kit totalling 64GB (4x16gb)
D-32 = Dual channel matched kit totalling 32GB (2x16gb)
GTZN = G.Skill Trident Z Neo (not sure what the C means)
F4 = DDR4
