17-55mm F2.8 IS - worth upgrading to from my 17-40L?
18 Oct 2002
Leamington Spa / Oxford
In a lot of situations, especially at social gatherings I find myself sticking to my Sigma 30mm F1.4 all the time, mainly because of it's low-light ability and reasonable view angle.
However I often want something wider, but my 17-40L at F4 often can't get enough light and lacks that nice shallow DOF. So I was thinking of trading up (or along..) to the 17-55mm IS. The way I figure it I get F2.8 if I need it for decent shallow DOF, the IS will allow me to shoot in lower light, and I get that extra reach which is handy.
It seems better in every way from most reviews, apart from the lack of weather sealing.. which I hope won't be a problem :confused:
I have one, I love it.
I was thinking 17-40L but the IS and F2.8 swayed it.
Its just as sharp as any L (according to people who have both!)
So yea, I would! :)
I used mine in the snow the other day, did have an umbrella though but still managed to get snowed under !
Sharp lens, good lens!
Excellent, looks like my 17-40L will be up for sale then :)
f2.8 to tickle your excitement :)
(iso800, af lock on downward arrow, IS enabled and shot at 1/10s 55mm)
I'd be tempted but its in the EF-S mount :( I'm looking to upgrade to a full size sensor later in the year so would have to sell it.
What other alternatives are therye to the 17-40mm that have a lower F number?
Tamron have a 17-50mm but it's a Di lens so again...no good on full frame!
there's the EF 16-35mm f/2.8, but its much less sharp than either the 17-40 or the 17-55.
if you're going to upgrade to full-frame, then you might want to look into the 24-70 f/2.8 :)
Based on your requirements, I'd say the 17-55 f/2.8 IS would be ideal for you
Go for it! :)
bobbyboy uk need's to post me his keyboard for that, will be cheaper postage wise than me posting my lens since it weighs more :p
Also WTF are Canon smoking, £30+ for a lens hood (EW-83J) - I just ordered a clone from ebay for under £6 !
