1k gaming machine help
24 Dec 2013
hi, ive been using overclockersuk for afew years now but only just signed up on forums.
my question im looking at building a gaming rig for 1k. i need everything OS case etc... i already have monitors.
should i go per-built or what? whatever gives the best for my money.
not bothered about watercooling as i dont overclock everything is at stock.
i havent build a machine from base up in awhile ive only been upgrading
so go ahead spec me - if it helps i play some mmo like rift, bf4, and soon elite dangerous and star citizen so it has to handle those games
i say 1k but i can go abit more to say £1300 but would like to keep as cheap as possible
thanks
Go for building your own - it's great fun, and cheaper. You also know what to do when something goes wrong. I'm just getting you a spec now
thanks, now im getting some idea on things. whats so differnt on graphics card i see the geforce has 2gb and the ati has 3gb would there be any performance diffrence between the two
looks great thanks, plus i can crossfire/sli in future
thanks guys, this is just what i needed a idea of things which is best i'll probably end up mix n matching some of the componets that have been suggested
thanks again
