Hi, make sure that if you are going for the AMD bundle, you will want to change the one you picked as you have picked the Watercooled bundle, which come with a water block rather than a air cooler.
good choice on the monitor too.
got a T190 atm, and 2 samsung tvs in the house too.
650-750W is absolutely all you'll need so don't bother getting anything higher than that. Antec cases are usually crap apart from p190 tbh. At that price you can get Cosmos which is like heaven better than the crappy A900 or 1200 flashy neon dust magnets.
Just my 2p.
Also you might consider getting just 1 5770 and see how that works for you and then adding second later if you feel like needing extra power. I'm pretty sure a single 5770 is good enough to handle most stuff even at high res unless you're 16AA 32AF maniac...
)what are the antecs like for reliability? I was always led to believe that the power supply is the one place you shouldnt skrimp on
EDIT: have read some reviews and its come out with glowing reports so good call thanks![]()
if his considering buying one 5770 i doubt his tlkin about buying a 5870.
its the 5850 his after
its a 5850 i would go for
yeah the 5870 would push me too far over the Girlfriend acceptamce levelits a 5850 i would go for
u decided on that psu yet
well definately not going for a corsair now, I like the look of the antec due to it being designed for the case, the customer support is something I can live with I reckon, and like i say all the reviews I have seen suggest its a great psu
just hope it never goes wrong lol i had a night mare with them
i'll be using enermax from now on
did u know we have a enermax and gigabyte authorised dealer in leicester
The Enermax 85+ revolution series of psus are AMAZING!! Everyone i know has nothing but good words to say about them but....The price...If you can stretch to one then you will probably never need a psu again...
no i didnt where abouts are they?
e-mail in trust i did add u to msn just accept
will drop one of the F3's for it
