You could reuse the hard drive in a new build if you are planning on giving the rest of the pc to your other Son.
8700K and RTX 2060. The other 2060 above is a bit cheaper, but the dual fan model should run a bit cooler/quieter. You also get Battlefield V or Anthem with the gpu.
Case is personal pref so you might want to change that. Just make sure it can fit the cooler. The H5 is 168mm so take that into account if going with that cooler and a different case.
My basket at Overclockers UK:
- 1 x Intel Core i7-8700K 3.7GHz (Coffee Lake) Socket LGA1151 Processor - OEM= £379.99
- 1 x Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30= £89.99
- 1 x Crucial MX500 500GB SATA 2.5-inch SATA 6.0Gb/s 7mm Solid State Drive= £64.99
- 1 x Fractal Design Meshify C Blackout Midi Tower Case - Black Light Tempered Glass= £84.95
- 1 x Antec EarthWatts Gold Pro 650W 80 Plus Gold Modular Power Supply= £79.99
- 1 x Gigabyte Z390 UD Intel Z390 (Socket 1151) DDR4 ATX Motherboard= £119.99
- 1 x Cryorig H5 Ultimate Single Tower Heatsink with 140mm Fan - Black Frame= £42.95
- 1 x Palit GeForce RTX 2060 Gaming Pro OC 6144MB GDDR6 PCI-Express Graphics Card= £338.99
