1st Time PC Gamer Needs help building a PC
Nothing wrong with Corsair PSU's! Have used 4 in builds and they have all been solid, they have their place with no high end GPU is being used.
Nothing wrong with Corsair PSU's! Have used 4 in builds and they have all been solid.
It doesn't have enough PCI-E connectors for the 290X lightening.
See my post above.
And molex-PCI-E adapter? no thanks.
You dont need a 750w PSU to power a single 290X lightening LOL!!
These will do it and have the connectors,
http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-AN&groupid=701&catid=123&subcat=2463
http://www.overclockers.co.uk/showproduct.php?prodid=CA-021-EA&groupid=701&catid=123&subcat=2463
Hmmm, CX range are a bit "budget".
Its unlikely to blow up, but a PSU from/made by Seasonic/Superflower etc will be better ripple, efficiency, quality internals (Japanese capacitors etc)
Ah yeah I remember now it's the other *X that are built by SeaSonic. Thats the bad thing about Corsair PSU's. Still it looks good enough to get the job done and for £65 it seems like a solid buy. That said I would probably go with the modular SeaSonic EVO and three nice PCIE cables.
Agreed, solid and strong PSUs.
I see, so would i need a better power supply to use that graphics card?
Yes, as per previous posts about what you need.
YOUR BASKET
1 x Seasonic M12II-620 EVO 620W '80 Plus Bronze' Power Supply £70.99
1 x BeQuiet Pure Power L8 630W '80 Plus Bronze' Modular Power Supply - With 120mm Silent Wing Fan Built in £69.95
1 x Antec TruePower Classic 750w '80 Plus Gold' Power Supply £69.95
1 x EVGA SuperNova G1 650W '80 Plus Gold' Modular Power Supply (120-G1-0650-XR) £69.95
Total : £290.44 (includes shipping : £8.00).
They all have the right number of PCI-E connectors or more.
YOUR BASKET
Intel Core i5-4690K 3.5GHz Quad-Core Processor - £167.50
Asus Z97-P ATX LGA1150 Motherboard - £67.99
G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory - £59.44
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive - £35.94
MSI Radeon R9 290X LE Lightning Edition - £239.99
Corsair 300R ATX Mid Tower Case - £56.27
EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX - £63.31
Total = £690.44
I had to change the tower because it said the R9 290 might block some bays in the 200R.
With the cash back site you sent me, i can buy the qualifying parts from any site right?
You have to buy the CPU+board same time same place, the other items dont matter.
Read the FAQs fully at the topcashback link.
http://www.corsair.com/en-gb/carbide-series-200r-compact-atx-case
So I guess you can take a HDD cage out for the card to fit.
Oh right thanks, is there more than 1 HHD cage right, thats just means if i wanted 2 hard drives i couldnt fit 2 with that R9 290 LE, what about if i want to put in an SSD could i do that if i take out a HDD cage?
I think you dont have to remove any cages (perhaps what you read was referring to doing 2 cards)?
http://img.hexus.net/v2/chassis/Corsair/200r/200R-08.jpg
http://images.anandtech.com/doci/6515/Small (6 of 8).jpg
See that pic, the top card will clearly miss the top of the cage, the lower one wont, but you will only have one card.
It was it says maximum length 430mm without drive cage. I was asking if i take out the drive cage how will that affect it, will i not be able to put a hard drive in? like is the drive cage one unit that comes out, or is it individual cages, i just wanted to know how it will negatively affect the build if i remove the cage.
