I'm looking at buying a new 1TB drive as I'm running out of space! Was just wondering if there are any new products coming out in the near future that might be worth hanging around for, either by being good or causing a drop in price of the existing stuff?
If not, what drive would you suggest? I'm after 1TB for as cheap as possible.
The Samsung F2 is a tenner cheaper than everything else, but it's out of stock and is only a 5400rpm. Is this too slow? I'm only using the drive for storage so don't think it'd be that noticeable?
If that's a no go then it looks like it's between the WD Caviar Green (32mb) or the Samsung F3. Thoughts?
Thanks for any help.
