1tb or 500gb? help please
19 Aug 2004
Newcastle
I was just about to buy a Samsung F3 500 but for an extra £20 I could get the 1TB.
Would it be quicker to run the OS and apps on a 500 or buy a 1TB and partition it?
Any advice appreciated :)
Buy a 1TB and partition it. You might as well make use out of the extra space for the price difference. :)
Yes go for 1TB cos it so cheap as Ive bought last week along with Windows 7 - pretty nicely.. it give you plenty of space, 500GB using one platter and 1TB using 2x500GB platter so it up to you but 1TB price seem quite cheap to grab it
Thanks for the comments :)
It was the 2 platters in the 1tb I was wondering about. I thought that might give a speed increase, but I wasn't sure how it would work out with a partition.
I dont mind about the extra space, I would rather have an efficient 500gb OS drive than a less efficient partitioned drive. I have an F1 that I'm going to use for extra storage or possibly another backup
Any more views before I make the order?
The two platters will give a speed increase. Partitioning will mean both partitions will be spread over both platters.
I'd definately say go for the 1TB drive.
