2 Barracudas and what to do?
  • Thread starter Thread starter Ed
  • Start date Start date
Ed
Ed
28 Apr 2004
Hastings
I've just bought another Barracuda 7200.10 320GB to go alongside the existing Barracuda 7200.10 250GB but after a bit of reading up it doesn't appear that I've got optimum performance from them.
First of all after fitting the new one I discovered a jumper which sets it to 1.5GB/s instead of the 3GB/s which I know my motherboard supports [MSI PowerUp Ed for Intel C2D]. Secondly, they are just set as C: and D: separate drives.
Is there anything to be had from pulling the drives out, setting them to 3GB/s and then configuring RAID0? What tangible results will I see from doing this, eg. boot times or playing FSX? I'm just trying to justify pulling the computer apart and reinstalling Windows which is a good mornings work.
Thanks for any wisdom.
Removing the jumper won't make any appreciable difference to real world performance, the drives aren't being constrained by SATA1 bandwidth.
You could RAID them and get a reasonable increase in sustained transfer rate but with the associated risk of data loss. In theory the Intel Matrix RAID should allow you to create a single 500Gb RAID0 array and still access the remaining 70Gb of the 320Gb drive as a single partition. This is a feature unique to the newer Intel controllers and I've not heard of anyone actually doing it so it's not guaranteed to work.
